stats on 4.6L
Old Nov 6, 2000 | 12:00 AM
bigbadliftedfordman's Avatar
Question stats on 4.6L
I'm soon to put 35" meats on my 97 F150 4x4...my question is with the stock setup 3.55 Limited-Slip, what kind of power loss can i expect? I'm worried about not being able to spin those meats in the sand. I know the new 4.6L are more powerful...what about 97s, and what can i do to help that if i squeeze those 35s on there? any help would be great...
-Brandon Warford
97 F150 XLT 4x4
3.55 Limited-Slip Diff
3" body
285/75R16 on stock
lots of stereo
true-dual flows
Old Nov 6, 2000 | 09:23 AM
OLE BLUE's Avatar
Post
The three most popular mods are (in no part. order):
1. Superchip +26HP, +40FT-LB
2. Intake system (K&N or Airaid) +10HP
3. Cat-back Exhaust +10-12HP
These are dyno tested number from an independant tester with a very good dyno.
So the numbers are correct.
If you wnat more as everyone always does, I did:
ASP Underdrive pullys +8HP
Dynomax Headers +12HP
Next on list of mods (as I am soon to go to 35" BFG's) is a gear change to 4.56's. It's not cheap but it will let you go with the larger tires and not suffer any ill effects.
Go to the online store of this site and you will find how to get several of these items.
Go here if you want to find out more info on the superchip. https://www.f150online.com/scpp/index.html
97 4X4 Flareside
4.6 5-Speed
Superchipped
ASP underdrives
Airaid
Dynamax headers
Borla Cat-back
Clear corners
5% Tint
285/75/16 BFG All terr.
16x8 AR Baha's
Rancho 9000's
Soon to come:
3" Perf. Acc. body lift
w/lift lips
315/75/16 BFG KO's
4000K bulbs
Old Nov 6, 2000 | 08:55 PM
Flats Man's Avatar
Cool
In addition to the above I would highly recommend 4:10 gears.
