Cleaning MAF Sensor
Yep my son and his wife just started teaching there this year. A pair of Docs.
Actually they are setting school history. I believe it is the first time that there have been a couple that have taught in the same department (Pschyc) there at the school.
Undoing the negative side terminal then turning everything on (with terminal off) then turn everything off and resetting terminal should do it. Just drive it normally so the computer can go throught the "learn" phase and it will be fine.
My question is how to reset (this must be done after cleaning the MAF?)
do i just remove the Neg terminal for 10 minutes or must i turn the key on while the Negitive if off the battery? Do i need to TAP the Negitive to the Positive at this time also.
sorry i am very new to this resetting thing. I have never done it and have had my truck for 7 years now.
99' F-250 5.4L-- Chip, K&N, Flowmasters and Throttle Body Spacer Whistle type. Anything else i sould be doing would be nice to know.
Thanks.
No just undo the negative terminal, turn on the key and turn on all the accesserys with the terminal still off.
Turn the key back to the off posistion and reconnect the terminal. The computer will relearn it's perimaters while you normally drive it.
