Ported MAF
Old Oct 23, 2000 | 06:27 AM
TREADMARKS's Avatar
Question Ported MAF
Has anyone ported or done anything else to the stock MAF? I am under the impression that a stock ported MAF may run a little leaner... Any thoughts or ideas?
Terry Deaton
99 F150 XLT, 2WD, 4.6, S/C, S/B, Superchip, K&N FIPK, FMS 9mm, +4s, Nerfs, Leer Top, Cow Catcher W/Bright A$$ Lights, True Duals with hi flow cats, 275 Dunlops with 3.08 gears, fat swaybars, Steeda front and Hellwig rear, Fabtech spindles with 2 inch blocks, B/E Performance Shift kit.
Coming Soon: 4.10s and Auburn Diff.
96 SVT COBRA (almost stock)
98 AERO black w/lotsa chrome
Speed Kills, drive a Chevy and live forever.
Old Oct 23, 2000 | 11:40 AM
JMC's Avatar
JMC
25 Year Member
Post
TREADMARKS,
My recommendtion is to leave the MAF alone. It is an 80mm MAF so it flows quite a bit. Check out http://www.corral.net/ and look up the tech section and look for Powerplant and finally SOHC MAF Post Removal. I tried this and it scerewed up the MAF. I tried cutting the tower in it to inclease flow and it set the ses light off.
I was lucky as I was able to glue the tower back and it is only about 1/4 inch shorter and the truck runs with the ses light off. SO now I have a modified MAF tower and it flowes a bit more air. Proceede at your own risk!
Regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks,
Borla Cat Back, Headman Headers,
Modified Air Cleaner Outlet Tube
and air box, Shortened MAF sensor tower,
K&N air filter,
Superchips
Old Oct 24, 2000 | 12:50 AM
TREADMARKS's Avatar
Post
Thanks for the heads up, JMC.
My quest for white tail pipes will continue to be a dream......
Terry Deaton
Old Oct 27, 2000 | 09:53 AM
Bart5.4's Avatar
Post
FYI, The MAF in the 5.4 is the same diameter as the V10. I would say it flows at least 300HP worth of air.
Y2K EB Expedition 4x4
K&N FIPK
Gibson SS Swept Side cat-back.
It's all good!
