Hey Magnacharger brothers.....
Hey guys!!
I was wondering if any of you guys have changed the blower pulley to a smaller id to speed up the boost yet? And if so, was it worth the expense?
'98 EB Expy 4x4
5.4L 3.73 LS
Trail.Tow & Skidplate Pkg.
DA MODS....
** Custom Fab. 4" Cold Air Enclosure
** Pro-M 80mm MAF w/Filter & SC cal.(Enclosed)
** WMS Velocity Tube
** 75mm Edelbrock/BBK TB
** Hand Ported TB/Intake Elbow/Spacer
** Magnason/Eaton M90 Supercharger
** Autometer Boost Gauge w/ A-pillar mounted pod
** Cust. Prog. Superchip
** JBA Jet Black Ceramic Coated Headers
** Stage 8 Locking Header Bolts
** Gibson Sweptside Catback
** IPD Rear Anti-Swaybar
** Bilstein Shocks
** Manik Grill/Brush and Rear Taillight Guards
** PIAA 520 Foglights
** Clear Corner Lens
** Stull Billet Grill and Bumper Insert
** Ford Molded Mud Guards
** Ford Hood Guard
** "EXPEDITION" Receiver Cover
COMING UP NEXT, IN THE FUTURE....
** 4.10 gears
** Brembo Crossed Drilled Brake Kit
** 18" Wheels, due to Brembos
** F1 Cobra style hood
"Its Sooo Big...Its Gotta to be Blown!"
'98 EB Expy 4x4
5.4L 3.73 LS
DA MODS....
** Bilstein Shocks
** Ford Hood Guard
** 4.10 gears
Not yet. I mentioned that to Chris at Magnacharger back when I bought mine. He sort of skipped around the question. He told me I couldn't get a different pulley from them at that time. I got the feeling that was not something he would recommend changing. He never said *don't change it*. But at the same time he didn't offer any info on doing so. And got off the subject rather quickly. The reason I was asking is, I'm getting 5 psi maximum. They say it's a 6 psi kit. He told me that was normal and it could be my guage is off. That's not impossible but I don't think so. It's a pretty high dollar hand held guage and has been handled with care. Also I'm assuming that changing the pulley will void the warranty. I really don't want a whole lot more boost. I think the truck could handle 7 or 8 psi as easily as 5 or 6 psi. My concern would be blower speed. All of Eaton's charts for the M90 stop at 12k rpm. I'm going to assume that is maximum rpm for that blower.
I wasn't able to find info relating to what the actual blower rpm is at maximum engine rpm with the pulley the kit comes with. Bottom line for me is, I would have to gather more info before making any changes. That's not something I would want to jump into head first and blind. It could be a very costly decision.
98 F-150 XLT 4X4 ORP Super Cab Short Bed, 4.6, Auto, 4.10's, Mag-Hytec diff. cover, Magnacharger supercharger, Superchip, Gibson single cat-back, 80/100w German head lamps, Warn HS9500i winch with semi hidden mount, Wrangler dual battery kit with red & yellow top Optima batteries, Torsion bars cranked up 2.5 turns. Needs one more door.
I also talked to Chris and got the same impression. I will wait a little longer and gather more info before I do the job on my truck. Besides,I just did a pile of mods at once and need to get them all sorted out before I go any further. I know I will need to send my chip back because of the 4:10 gears, MAF, and TB mods. I plan to dyno on the 4th of Nov and will let you know how it went.
98 White 4.6 Triton STX (It's not an STX anymore) Flairside,Class III hitch, Blue Cobra Stripes, Euro Lid by Astro, Bed Rug, Fiero Wing, Air Dam,Westin Step Bars, Ground Force 2-4 Drop,Custom MB Phantom Wheels,clear corner lenses,monster battery terminals,Custom Programmed Super Chip,BBK 75mm TB, Pro M 80mm MAF,Pillar Pod w/ boost and trans temp,Jacobs DIS Ignition,New transmission on the way,4:10 gears, custom intake tube, Jet coated JBA stainless headers, Magna Flow Muffler with Stainless Duals and of course fully Blown by Magnacharger!
Flatsman has the plan! Wait until the warranty expires, then consider the pulley. Fred also said we need to get with Chris so he can provide the PROCEDURE for changing the pulley.
6 to 8 psi SHOULD be safe, when using HIGH octane fuel.
In the meantime, consider the MAF, TB, and a TB spacer (to increase plenum volume) just as Flatsman did. These mods, combined with a good exhaust system will maximize output at the boost levels we are seeing with the stock pulley.
I have read, but have not verified, the stock MAF I.D. is 80 mm. If this is true, do the TB and spacer first, and match this diameter. When purchasing these parts, try find composite or phenolic construction, because these materials do not transfer as much heat.
Try to make these mods one at a time, then test drive. This way you can mark your progress, and if any problems do arise, it will be easier to sort them out.
BTW- Don't forget to duct in cool air. Blowers really love the cooler air!
BLOWN 4.6 5-speed
Where we started.
After a facelift.
Latest MOD!
Trixters-Playground!
trixters-playground@excite.com
F-150online Photo Album
crash@f150fanatic.com
MAGNACHARGER
ALLEN
BLOWN 4.6 5-speed
Where we started.
After a facelift.
Latest MOD!
MAGNACHARGER
ALLEN
