Tune Up?
Old Oct 13, 2000 | 04:06 AM
jefferydm's Avatar
Question Tune Up?
My 97 XLT has 65K miles on it. Never has had a tune up. It runs well, although I have noticed some pinging in the cooler early morning, which goes away when the engine warms up. My question is, I'm probably going to have the truck serviced soon for some brake work, would it be a good idea to have them replace the plugs, check the timing etc? I was also thinking about having them replace the belts. Just as proactive preventative maintenance measure. Any thing else? I had the fuel filter replaced at 50K.
97 F150 XLT 4.6L 2WD
Old Oct 13, 2000 | 10:47 AM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Exclamation
I have 46k on mine and a mechanic,not ford tech,told me that the plugs may not need to be replaced until 60k. Your plugs
may be carbon fouled causing the preignition. I'd get them replaced. I don't know about the belt,mine was replaced three times,kept squealing on me. I found the problem later(loose a/c compressor) Does the replace every 4 years still apply,anyone?(for belts and hoses?) The plug change was quoted to
me at a dealer,,,$185!! minus the plugs,I
had my own! They said "they're a real bear to do!" So I'll wait for 60k to get it done. Still have the plugs(cost me $50)
Has the air filter been replaced regularly?
The timing is set in the comp. and is crank triggered,so it's probably fine
,,,,,good luck on the tune up,,,,,98
98 F-150 4.6 Litre XLT2wd Ext. cab
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Westin nerfs blk .powdercoat
Clear front corners
Cobra 75WXST cb w/weather alert
Kenwood cd w/Radio Shack speakers,don't laugh it sounds pretty good
On the way/wheels,tires,air dam, etc..etc.......
doin the monochromatic boogie
on the front end.Billet grilles on order
Hoping for deliverance from door crack hell.
