engine won't idle
Help! My '97 F150 4x2 4.6 5spd will run but won't idle. The plugs were changed over a month ago and the fuel filter tonight (thinking that may be the problem). The engine cranks and runs normal as long as the gas pedal is being pushed. But as soon as it is released the engine dies. Any ideas would be greatly appreciated.
Power feels fine, and it has 62K
'97 F150 XLT SC 4x2 Oxford White. Kenwood CD player, cheap amp and cheap 6x9's. K&N filter and Bosch plugs. Goodyear 265/85 GSA tires
Future modifications planned are Gibson exhaust and headers, K&N Generation II, chip, and 2" front suspension lift
[This message has been edited by K2rider (edited 08-09-1999).]
Did this come on gradual or all of a sudden. Did you make some change right before it happened. I've seen bad plugs or plug wires (bad or loose ends) cause this. Unless it's electronic based, I think the key is that it runs fine with higher RPMs yet poorly at idle. See if your dealer will let you have a peak at their service manual, they should have a diagnostic tree in there. Good Luck
I agree with gmc305, try a TPS. Unless you have friends at a ford dealership that will test it for you.
stock 98 XL, Reg. cab,4.6, Auto, Tow package, 255/70R16 on styled steel wheels,3.55LS, Black with chrome grille and bumpers! MODS: custom stereo by me, building speaker box was a !@#$%.
did you just recently re-oil your K&N? too much oil and it causes many problems.
David
'99 F150 XLT SC, STYLESIDE
4X4 ORP 5.4L, AUTOMATIC,
139wb, Rhino, K&N,
BugGuard, RainGuards
SHE SAID YES! SHE SAID YES!
SUPERCHIP MOD SOON!
David
139wb, Rhino, K&N,
SUPERCHIP MOD SOON!
Thanks for your ideas. The problem turned out to be the IAC (Idle Air Control) valve. It sits right on top of the 4.6 and couldn't have been easier to change. It was about $60 from my local dealer. I figured it out what the problem was with the help of you all and my new Hayne's repair manual.
Thanks Again!!
K2
Thanks Again!!
K2
This happened to me yesterday and I was away from home. For a temporary fix to get you on your way, just give the valve a few hard taps to unstick it.
You can use your lug wrench if nothing else is available. As for the location, on my 5.4L it's on top the motor almost directly under the right windshield wiper post. There's a two inch hose feeding out of it to the right.
1999 F-150 Lariat 4x2
Reg cab Short box Styleside
5.4L 3.55LS
Dark Toreador Red/Gold
VentShades
Tow Pkg
Line-X
Stickers to make it go fast
Future mods:
More Stickers
5.4L 3.55LS
VentShades
Tow Pkg
Line-X
Future mods:
More Stickers
