I want more UMPH from my 4.6!
I am looking for any CHEAP way of adding torque and a few ponies to my 4.6L. Already have a tru dual with flows. I am currently running 35x12.5s and just want the extra umph...but don't wanna spend over a grand (and am trying to avoid voiding that ext. warranty)...any ideas, anyone?
Thanks, Brandon
97 F150 Sport 4x4 4.6L 35s and 3" body. 2" torsion adjustment.
Thanks, Brandon
K&N filter, pulleys, chip, and a mild nitrous kit should put you in under a grand. If you are worried about the NOS voiding your warranty, the kit is very easy to remove if you have to go in for major service. If nitrous isn't in your game, substitute a set of headers, a slightly larger t/b(no more than 5mm over stock..), and/or an aftermarket ignition system. I'm not definate about the truck applications but these are tried and true on the Mustang 4.6L brethren.
1999 F-150 4.2L
-just bought it, have to mod it-
1987 Mustang LX Hatchback
351W
"Strictly strip, 250 shot nitrous, going for broke"
NEEDS TRANNY!
"Burying the competition, one bowtie at a time"
1999 F-150 4.2L
351W
NEEDS TRANNY!
BigBadRedLiftedFordMan,
Change your differential gears to 4.10 or 4.30:1 Note; your front differential requires a reverse cut gear. Should cost just about $1000.00.
Regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks,
Borla Cat Back, Headman Headers,
Modified Air Cleaner Outlet Tube
and air box, Shortened MAF sensor tower,
K&N air filter,
Superchips
Regards
Jean Marc Chartier
K&N air filter,
Superchips
Welcome guys!!
I would start with pulling the restrictor from the fenderwell. The I.D. is about 3/4" smaller than the throttle body. Put a dryer duct in it's place. You can also search for threads on "Airbox mods", but make sure you keep cool air ducted into the engine. You can follow the links in my signature to get a look at my air duct.
Headers, a K&N filter, a larger throttle body, MAF, and a Superchip! It's a start!
ILUVNOS-
Where do you live? Maybe A few of us can get together. I am from Tulsa, and I go back often.
Drop me a line!
BLOWN 4.6 5-speed
Where we started.
After a facelift.
Latest MOD!
Trixters-Playground!
trixters-playground@excite.com
F-150online Photo Album
crash@f150fanatic.com
MAGNACHARGER
ALLEN
[This message has been edited by crash1 (edited 09-29-2000).]
ILUVNOS-
Drop me a line!
BLOWN 4.6 5-speed
Where we started.
After a facelift.
Latest MOD!
MAGNACHARGER
ALLEN
BigBad,
Check out my sig. I absolutely agree with JMC's answer. Being that you have 35's, I would install at least 4.30's and probably 4.56's. It will feel like you added a hundred horses. Depending on what gears you have now, you may gain a fraction of a mpg. At worst you may lose a mpg. But the felt power difference will definately put a smile on your face. If I could go back and do it again, without a doubt, the gears would be the first mod. It didn't add any horsepower but it made the most difference. As I have said before, the supercharger is good but it takes a few hundred rpm to kick in. The gear change added instant grunt and is available at *all* rpm's. You won't regret it!
98 F-150 XLT 4X4 ORP Super Cab Short Bed, 4.6, Auto, 4.10's, Mag-Hytec diff. cover, Magnacharger supercharger, Superchip, Gibson single cat-back, 80/100w German head lamps, Warn HS9500i winch with semi hidden mount, Wrangler dual battery kit with red & yellow top Optima batteries, Torsion bars cranked up 2.5 turns. Needs one more door.
