f150freak
Old Sep 18, 2000 | 08:52 AM
road.rage's Avatar
Post f150freak
I apoligize if I my seem to be a pest but I am desparate this part cost $188.00+tax.
If you could open your air box and describe what they did at least I would know if I need to buy a new one. My truck has been down since friday and ordering one takes 4 days.
thanks for your time.
road.rage@netzero.net
F150 4x2 4.2L 5-speed XL
SmittyBuilt:Brushguard
Nerfbars
Tires:Micky Thompsons Baha Radials MTX 285/75/r16
Vent visor:Bug Guard
Window vents
Hypertech:Superchip
Jacobs Ignition Milage Master,Jacobs Super conductor Wires
Flexlite 150 electric fan
fabtech 3" front lift coils.
Trailmaster 2"lift blocks
Add a Leaf spring
Monroe sensatrack: Front/rear shocks
4.10 gears
Pioneer audio single disk tuner/cd
Planet audio speekers
Billit shift ****
Window Tint
Wolf bench seat contractors consoles
Cab clearence lights
Xenon sport flares
Reese frame hitch
Blue wire loom
Redline Synthetic:5w30 motoroil,Atf trany fluid,75w140 gear lube
Hellwig rear sway bar
polyurithane upgrade endlinks front swaybar
pilot fog lamps
vortecs free flow exaust
Swiss Camper top
Old Sep 18, 2000 | 05:04 PM
ps398's Avatar
Post
Even if you find out what his looks like, that won't change the fact that you may have damaged the sensor itself. I think you may just have to bite the bullet and get a new one and chalk it all up to experience.
Old Sep 18, 2000 | 05:11 PM
Andthensometoo's Avatar
Post
Let me see if I get this right: You may have damaged your maf, your Truck does not run, You have the following on your Truck now,
Nerfbars
Window vents
Hypertech:Superchip
Add a Leaf spring
4.10 gears
Billit shift ****
Window Tint
Xenon sport flares
Reese frame hitch
Blue wire loom
pilot fog lamps
Swiss Camper top
....and you don't want to spend $188 bucks?
Old Sep 18, 2000 | 09:25 PM
road.rage's Avatar
Exclamation
code in computer says fuel to lean runs terrible and money is no problem but I want better performance not stock goal (THE ULTIMATE V6) hay its in my blood just need to get more air to pass by the senser just want to know what f150freak had done to his because my senser is fine but the housing I modified for I figure 30% more air flow.
Nerfbars
Window vents
Hypertech:Superchip
Add a Leaf spring
4.10 gears
Billit shift ****
Window Tint
Xenon sport flares
Reese frame hitch
Blue wire loom
pilot fog lamps
Swiss Camper top
Old Sep 19, 2000 | 12:44 AM
f150freak's Avatar
Post
It looks like they just honed it out a few mills. it looks like they didn't touch the center peice(pickup, contacts,whatever its called). Again look at one of your previous posts to me and there is a web address there. They did the work for me and could describe the process much better than I could. If you missed the first time the address is http://www.d6racing.com/
Old Sep 20, 2000 | 01:50 PM
crash1's Avatar
Post
Are you porting the MAF because there are no aftermarket parts available?
Old Sep 20, 2000 | 03:00 PM
road.rage's Avatar
Post
The answer is yes. I checked all over no one carries an aftermarket or high proformance senser. I finaly got the truck up and running I ported the sampling tube to compansate for the additional air flow I am getting. The truck runs like a bat out of hell. I don't advise this because it takes a lot of trial by error(check engine light). But it was worth the $0 cost upgrade. If anyone does this make sure to remove the probe from the housing so you don't damage it.
Nerfbars
Window vents
Hypertech:Superchip
Add a Leaf spring
4.10 gears
Billit shift ****
Window Tint
Xenon sport flares
Reese frame hitch
Blue wire loom
pilot fog lamps
Swiss Camper top
