K&N
Old Sep 9, 2000 | 02:06 PM
cphilip's Avatar
Post
The use of Filter Gasket Grease is in order if you are seeing any dust. Thats why K&N makes one. So do others.
Old Sep 9, 2000 | 09:00 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Post
I noticed a little dust one time when I took
the filter off to clean it. I wasn't too alarmed and used a little more oil the next time,no dust. I've never had the oil clog any sensors,maf or otherwise.
98 F-150 4.6 Litre XLT2wd Ext. cab
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips
color matched snuglid
Superchip!!!
Westin nerfs blk powdercoat
Cobra 75WXST cb w/weather alert
Kenwood cd w/RS speakers,don't laugh it sounds pretty good
On the way/wheels,tires,air dam, etc..etc.......
doin the monochromatic boogie
on the front end.Billet grilles on order
Old Sep 9, 2000 | 09:07 PM
eph1fifty's Avatar
Post
Correct me if I'm wrong, but doesn't Ford offer a K&N filter with some of the Mustangs?
So far I have done 20,000 kms with my K&N and no probs...
Check out my site, send me pics:
cooltrucks.net
My email: webmaster@cooltrucks.net
Also: nerdzfx.com
1997 F150 4x4 XLT with ORP 4.2L V6 and 5-speed manual.
Old Sep 10, 2000 | 12:12 AM
98fword's Avatar
Post
The dust particles in my intake were very, very fine and it was an extemely thin layer. I had to hold the ducting at just the right angle to see it. And then it was hard to see. I wiped my finger across it and held it up to the light. I could definately see it then. I think michael_hovis may have a point. The sealing surface on the K&N isn't as thick or designed the same as the stock unit. When I put the stock filter back in, it took quite a bit more effort to get the two halves clamped back together than it did with the K&N. I'm not to run a filter that I have to make an extra effort to get sealed because of a design oversight. The small amount of performance gain is not worth the trouble to me. I would rather *know* that there's not a bunch of crap making it's way into my engine. The Magnacharger will take up the slack!
98 F-150 XLT 4X4 ORP Super Cab Short Bed, 4.6, Auto, 4.10's, Mag-Hytec diff. cover, Magnacharger supercharger, Superchip, Gibson single cat-back, 80/100w German head lamps, Warn HS9500i winch with semi hidden mount, Wrangler dual battery kit with red & yellow top Optima batteries, Torsion bars cranked up 2.5 turns. Needs one more door.
Old Sep 10, 2000 | 10:52 AM
TREADMARKS's Avatar
Cool
I have had a Stock type K&N replacement in both my 99 F150 and 96 SVT Cobra, both for more than 20k miles. Whe I replaced the stock systems with FIPKs yesterday I searched for dust/debris in the intake track and found none at all. Both of these filters had been at least a year without cleaning. The only DIRTY area on the induction was the throttle body, more so on the truck. I am guessing that with the 308 gears and the new 275 tires the increase in reversion in the intake contributed to the oily build up. I'm sure that there is alot less reversion in the cobra, as it was much cleaner. OH well both are clean now and running smoother than ever.. I will stick with the High flow K&N, and figure out some way to get some cool fresh air to it
Terry Deaton
99 F150 XLT 4.6 S/C
96 SVT COBRA
98 AERO
Speed Kills, drive a Chevy and live forever.
Old Sep 12, 2000 | 08:31 AM
RCL's Avatar
RCL
Talking
I checked my system and there is no dust after about 5K miles. Yeah! Hope it stays that way.
RCL
2000 XLT 4.6 V8 5speed 4x4 RC SB Amazon Green
Modifications:
K&N
Mobil 1
Magnum Deflecta-Shield
Soft Snapless Tonneau
Ford Duraliner
Old Sep 12, 2000 | 08:56 AM
RED Y2K SPORT's Avatar
Talking
"eph1fifty"
Don't know if Mustangs come with K&N, but do know Ford sells K&N as an accessory throught heir parts departments,only difference is they are blue!! I have the "drop in" on my 98 Expy, and the Generation II system on my F-150 love them. The Gen II does generate more horses, Mike Troyer has posted the numbers several times in the Computer Chips
threads.
2000 F-150, XLT, SPORT 4X4, BRIGHT RED/DARK GRAPHITE, SUPER CAB,
SHORT BED, 5.4L, AUTO, 3:55LS, TOW PACKAGE, HD COOLING/ELECT, SKID PLATES
SPORT CLOTH SIX WAY POWER CAPTAIN'S CHAIRS, CONSOLE, SINGLE CD,
CRUISE,ESOF,REMOTE KEYLESS, FORD SNAPLESS TONNEAU COVER, FORD BEDLINER,
FORD MOLDED SPLASH GUARDS, FORD BODY COLOR CABSTEPS,
MODS: CATCH ALL FRONT MATS, LUND DEFLECTOR, FORD VENT SHADES,
GIBSON SWEPTSIDE CATBACK,
K&N GENII FIPK,
FORD HITCH COVER
NEXT: SUPERCHIP!!
Old Sep 13, 2000 | 03:48 PM
TexasSport's Avatar
Post
I have read that when you do the mods with the K&N that in order to feel the difference you must reset you computer.
is this true?
and what if you just replace the filter and not the full blown FIPK, do you still have to reset your computer? and how do you go about it, just unplug your battery or what?
Old Sep 13, 2000 | 05:34 PM
lightningcrashz's Avatar
Post
My filter is a JET filter and I do have a little bit of that fine dust.I think it was from one trip I made down a dirt road that was coated with the fine dust.Anyway I think all the aftermarket air filters do let a little of that dust in.
JET air filter
delta tool box
pumpin' stereo
class III reciever hitch
spray in bedliner
headlight covers
custom painted taillight covers
cranked torsion bars 2000 black F150 4x4 sport v-6
lightningcrashz@hotmail.com
Talking
You don't HAVE to reset the computer because it will "learn" the new parameters over time, but it is recommended to reset it. Disconnect the negative cable and turn on the headlight switch for about 5 minutes (to drain any residual electricty in some components) shut off the headlight switch and reconnect the negative cable, and you are a done deal. When you start it all gauges should peg for a second or so, that is your indication the computer has been reset.
Old Sep 14, 2000 | 04:55 PM
TexasSport's Avatar
Thumbs up
Thanks,
getting off work now and will go home and do this. has anyone just added the filter and not the FIPK and gained MPG? or for that matter lost MPG.
Old Sep 14, 2000 | 05:18 PM
Post
yes, your mpg should go up but not by a whole lot.I gained about 1 mpg.
