dangerously high idle...sometimes
Please, can ANYBODY help me??!!
My '99 F150 is intermittantly idling at 2500rpm. in gear or not, with no throttle input. Ive taken it to the shop under warrenty 3 times over the last year for this problem, but no one can ID the problem (reliably). This problem is dragging me into intersections and curves WAY too fast and I'm seriously freaked out about it. My dealer/mechanic seems to be lost, so I want to ask other owners.
CAN ANYONE HELP ME?
I love my truck and I don't want to kill it (or my family...). ANY assistance would be welcome...
[This message has been edited by leanintree (edited 09-09-2000).]
CAN ANYONE HELP ME?
tell your ford dealership to check oasis there are a couple tsb on older modles for a binding throttle cable, and a updated pcv coduit tubing and a new iac. I know your is a 99, but it would be a good idea to have your iac replaced and the cable checked for binding ( cable tsb concern occurs more in cooler climates )
This is similar to what black f150 offroad
was talking about.
Recall Campaigns For The 1999 F150
NHTSA CAMPAIGN ID Number: 98V192000
Component: FUEL:THROTTLE LINKAGES:ACCELERATOR:FLEXIBLE
Manufacturer: FORD MOTOR COMPANY
Mfg. Campaign #: 98S22
Year: 1999
Make: FORD TRUCK
Model: F150
Potential Number of Units Affected: 1500
Manufactured From: JUN 1998 To: AUG 1998
Year of Recall: '98
Type of Report: Vehicle
Summary:
Vehicle Description: Light duty pickup trucks. A speed control cable may not have fully seated into the accelerator bracket at time of installation. If the cable is not fully seated into this bracket, the cable could separate from the bracket.
A loose cable can result in the throttle not fully returning to idle and cause an increase in stopping distance.
Dealers will add a retaining clip to the speed control cable fitting at the accelerator bracket. Ford is notifying dealers on or about August 11, 1998. These vehicles have not yet been released for sale to the public.
2000 F-150 XLT, 4x2, 5.4L Supercab, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with heavy duty cooling package, Heavy duty shocks, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, FORD bedliner, FORD black tubular cab steps, K&N air filter, mar-hyde rubberized undercoating, Modine climate filtration system, Bugflector II, Mobil 1 oil and filter, Build date 7/00
[This message has been edited by Dustoff (edited 09-10-2000).]
was talking about.
Year: 1999
Make: FORD TRUCK
Model: F150
Year of Recall: '98
Summary:
I just wanted to add some more information for you, the codiut tubbing was to prevent pcv icing wich could cause the throttle body to stick, personally i have worke on rangers and a 00 mustang 3.8 wich would intermitantly have a fast idle, you would be driving along and sudenly the idle would jump to the area of 1500 rpm, i replaced the iac and the problem was resolved, the tech who works on your truck should also use wds - datta logger and monior the tps pids, as a fluctating tp sensor can also cause a high idle, plus it is always a good idea to check the basics, i have seen floor mats sliding and causing problems as well.
My wife had a 92 Taurus that did the same thing. The Dealer did an idle stratagy what ever that is and it was fixed for about a year then came back. We ended up trading it off.It also took them several times before they found a temporary fix.
Dennis
Dennis
WOO-HOO!!!
Thanks to all involved for actually answering (I posted the question on Edmunds Townhall and all I got was some comedian suggesting that I either torch my truck or send for a priest to exorcise it...).
Dustoff: Thanx, but I already knew about the recall safety bulletin. Brought a copy to mechanic last time I took it in. He said he checked it, but I'm not convinced... (oh yes, since I last looked, the recall has been updated to include '99s in the same build period mine is...maybe I'll have them look into it again.)
B-F150-OR: In english please? My acronym translater is on the fritz... However, I want you to know that I'm taking a copy of your posts to the mechanic along with the truck. I don't know as much as I'd like, but I do know when to listen to those that know more than me. (and I pride myself on a functioning bull****-o-meter...)
Thanx to all who posted, Ill keep you posted & if you think of anything else, you know where I'll be...
Leanintree
Leanintree
check my response to thread "2000 RPM in neutral" this may be your answer. It is exactly what my ranger was doing. Also same as "black f150 offroad" said above.
2000 F-150, XLT, SC, 5.4, 4X4, 355 LS, ORP, Black/Silver, class III, single CD, sliding glass, med. gray, keyless, elect. shift, engine date 8-18-99, Superchip. '93 Harley Fatboy Black & tons of chrome
Who says surfing is a waste of time (other than the boss)?
Thanx to everyones input, I'm beginning to see a pattern emerging here. Deductive reasoning would suggest that the IAS is a very logical place to start. (even if I couldn't find it myself...grrr...)
Trucks going in tonight to be worked on tomorrow (shop still thinks I live 130 miles away like when I bought the truck...who am I to disabuse them if it means they will get on it NOW)so I'll keep one and all posted.
thanx folks!!!
LEANINTREE
[This message has been edited by leanintree (edited 09-10-2000).]
thanx folks!!!
LEANINTREE
