Oil filter help
Old Sep 2, 2000 | 03:07 PM
bigbo's Avatar
Angry Oil filter help
I had a 1998 f-150 4.6 supercab and the oil filter was in a A#1 spot. So when I purchased my 1999 f150 super cab with 4 doors not 3 like the previous year. I never in my wildest dreams thought they would completely relocate the filter to a Ridiculous spot. I have changed transmisions quicker then my oil filter. Can anyone please help me out. I must be missing something it cant be this difficult.
Old Sep 2, 2000 | 05:24 PM
Jupiterak's Avatar
Post
It's a pain, and even worse if the filter has oil and grime on it. The only suggestion I can give is when you buy a new filter; get the K&N oil filter. It has a 1" nut at the end. It's alot easier using a 1" stubby wrench to get them off in the future.
Old Sep 2, 2000 | 07:58 PM
Dustoff's Avatar
Post
I know exactly what you mean! My 98 5.4L had the remote oil cooler and it was so simple to change the filter.
My advice is to turn your wheels all the way to the right (to passenger side)...to move the Pitman arm out of your way. It extends from the power steering pump to the tie rod and is right in your way with the wheels aligned straight ahead. This will give you a clearer path to get to the oil filter and make it easier to remove the old filter and install the new one. After the first change...it will not be that difficult.
2000 F-150 XLT, 4x2, 5.4L Supercab, LEV, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with heavy duty cooling package, Heavy duty shocks, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, FORD bedliner, FORD black tubular cab steps, K&N air filter, mar-hyde rubberized undercoating, Modine climate filtration system, Bugflector II, Mobil 1 oil and filter, Build date 7/00
Old Sep 3, 2000 | 08:30 AM
bigbo's Avatar
Thumbs up
Thanks Guys for the Help, This is the second oil change i've done on this truck. And i dont remember what the hell i did the first time to get the filter off. I went with amsoil so I wouldnt have to change it as often. I will Try the KN filter, that sounds good since there is a nut on the end. Thanks again.
Old Sep 3, 2000 | 09:28 AM
msparks's Avatar
Post
eom
[This message has been edited by msparks (edited 09-04-2000).]
