Carbon buildup iinside TB & manifold
Old Sep 1, 2000 | 10:11 PM
Jupiterak's Avatar
Question Carbon buildup iinside TB & manifold
While installing a WMS velocity tube today. I notice there was alot of carbon buildup inside the throttle body and intake manifold. I took my finger and was able to wipe a small smudge off. The truck has 20K miles. Is this normal? I plan on getting some carb cleaner tomorrow to help clean some of the gunk out. Any recommendations on cleaning inside or carb cleaners??
1999 F250 LD S/C XLT 4x4
5.4L, 3.73, 4R100 trans.
Flowmaster 40 "DF" series, K&N, Superchip, Rancho RSX shocks, Stull billet grille, 2-PIAA Pro80XT's (120W), 2-KC Daylighters (150W)
265/70 R17 BFG AT KO's on 17x8 American Racing Atlas rims
Kenwood 7007 CD, Alpine 3342 Signal Processor, Alpine MRV-F353 5Ch. Amp, Pioneer TS-A6865 3-way speakers, MTX Thunderforms. CompuStar alarm/autostart.
Old Sep 2, 2000 | 12:14 AM
Matt90GT's Avatar
Post
with the EGR/emmissions of the engines, you get some exhaust gasses recirculated back thru the intake. This is what causes the black soot. There is really nothing that you can do to prevent it.
Cleaning it, the BEST cleaner for it is at Napa. get their house brand carb spray. It is in a light blue can with yellow letters. It just cuts that stuff off!! anything else you will be wasting your money.
Once you have cleaned it, wait about 1 hour before starting. It will be hard to start since you will have all the carb cleaner in the intake there.
Old Sep 2, 2000 | 05:27 AM
F-trucks's Avatar
Thumbs up
JUPITERAK dont use regular carb cleaner to clean it FORD puts a special anti sludge coating on these and the carb cleaner will remove the coating and will damage the throttle body bores! however if you go to NAPA AUTO PARTS they sell a special cleaner for cleaning the special coated throttle bodys that dont harm the coating it is made by 3M brand prodcts and its about $4.00 a can
Old Sep 2, 2000 | 08:11 PM
red97's Avatar
Post
I have heard that spraying cleaner into the TB is bad for sensors, etc. That it is better if you remove it to clean it.
Red '97 F-150 SC 4x4 off-road, 16" rims instead of factory 17"'s(borrowed from old '97 reg cab), BFG 265/75 16 all terrain T/A, K&N filter with modified air box, Flowmaster 40 with duals out back, Expedition center console, 3" rear seat lift, after market stereo seen at HTTP://members.sounddomain.com/red97,
Old Sep 2, 2000 | 09:15 PM
Jupiterak's Avatar
Post
I sprayed 1/4 of a can of the NAPA carb cleaner. Took for a 15 min. drive. This morning I did the same again. Now it's VERY clean. Thanks to all for the help.
Old Sep 2, 2000 | 10:10 PM
crash1's Avatar
Exclamation
Yes, you will definitely clean the throttle body. No doubt.
The goal is to remove the trash from the throttle body, without removing the coating. This is why there is a decal that says "Do not clean inside throttle body".
Ford makes a special throttle body cleaner which will do this job and lubricate the throttle valve. It is best to follow the instructions, no scrubbing. If you cannot find this stuff, use ONLY "BG" throttle body cleaner. These two cleaners work extremely well.
Bear in mind, you may never have any problems, but many times I have seen intermittent rough idle and stalling. Rolling idle is another common problem.
Just trying to help, I'm not flaming anyone here.
Crash
BLOWN 4.6 5-speed
Where we started.
After a facelift.
MAGNACHARGER!!!
Trixters-Playground!
trixters-playground@excite.com
F-150online Photo Album
crash@f150fanatic.com
MAGNACHARGER
ALLEN
