Need Help w/ Airaid
Old Sep 1, 2000 | 09:40 PM
F150IslandBoy's Avatar
Post Need Help w/ Airaid
I installed the Airaid FIPK without any problems. I did just like the instructions and everything went smooth. The first time I started the motor everything was great and I test drove it around the block a few times. The second time I started the motor the "check engine" light came on but I didn't panic because I read a lot of other postings reguarding FIPK's. So I removed the MAF sensor and cleaned it. I reset the computer again. I went through this process three times. But it seems like every second time I start the motor after I reset the computer the "check engine" light comes back on. I can drive for 30 miles or just let it idle for a minute the first time after I reset computer and it's OK. But the second time after resettting computer the light comes on shortly after the system goes through its initial system check. Does anyone know what could be the problem? TIA
1997 F150 Lariat F150IslandBoy
SuperCab, Toreador Red w/ Gold, Styleside, 4.6L, A/T, A/C, 3.55 3800 Limited Slip, Class 3 Tow Package, Leather Captain Seats, Sliding Rear Window.
Modifications:
Airaid FIPK, Bugflector II, Viper 500ESP Alarm, Pendaliner Bedliner, Cobra Trapshooter 3 Radar Detector, CARR Tubular Nerf Bars, NFA 1400 Compact 55W=>85W Halogen O.E. Lights, Durango 255/70R16, Chrome eyelet tie downs, Smoked front lic. plate cover
Old Sep 1, 2000 | 10:17 PM
Jupiterak's Avatar
Post
When you say "reset the computer," did you actually disconnect the battery? The best way is to disconnect the battery and then turn on the headlamps to drain any voltage from from the computer, capacitors, etc.
Also, make sure you don't have any vacuum leaks and recheck all hose connections.
Old Sep 1, 2000 | 10:26 PM
Post
Yeah, I disconnected the battery and turned on the headlights for 15 minutes before reconnecting battery. I have checked all connections and no vacuum leaks. It runs great all the time with the light on or off. After I reset computer, I can drive as long as I want without the light comming on. It's the second time I start the motor the light comes on.
Modifications:
Old Sep 1, 2000 | 10:44 PM
Jupiterak's Avatar
Unhappy
Sorry, I can't help. That's kinda unusual for the C.E. light to come on every 2nd time. Try doing a search for Airaids in the Engine forum. There's alot of airaid owners here. If all else fails try giving the company a call.
Good luck.
