Bad milage drop.....
Hi all,
Usually I just lurk, but my F-150 has had a serious drop in milage recently, and I wanted to check and see if anyone might have any tech advice on this.
Current config:
97 F150 XLT
5.4 L
K&N Filter
Gibson Super Truck Exhuast
Drop from 15-16 mpg down to 11-12 mpg. Have tried reset system computer, and varied gasoline to insure it wasnt just the gas at the place I regularly fill.
Anyway any tips or tech advice would be greatly appreciated.
My thanks
Rik
Denver
Current config:
97 F150 XLT
5.4 L
K&N Filter
My thanks
Rik
Denver
I'll assume you've cleaned and re-oiled your air filter.
Did you take a q-tip and carefully clean the two little wires in the MAF? Sometimes oil from the K&N can coat those and indicate false readings to the computer.
Has a baffle broke loose in your muffler blocking exhaust gases?
Yes, as posted above, plugs, wires, etc... tune up.
* Filter cleaned and oiled.
* Muffler seems OK doesn't appear to be a blockage as exhuast gasses are passing from the outlet at what I would assume to be normal amounts.
* Tires the same.
MAS Airflow sensor! there's one I didn't think of will inspect it imeediately and post findings.
Thanks very much gang!
* Tires the same.
It could also be a bad O2 sensor. I had a bad O2 sensor that was not coding the computer and never turned on the "CHECK ENGINE" light. After I took it to the dealership they said they didn't understand why it didn't code the computer. Mine also had a rotten egg smell from the exhaust.
Increase your tire psi to compensate for the colder air--reduced air psi if you haven't already done it.
No one has mentioned your fuel filter--supposed to be changed every 15,000 (I think) miles. If it's clogged, that usually results in reduced high rpm power but it might affect your mpg too? Worn plugs will usually show up with hard staring but could be the problem too--not going to be fun changin' them rascals
Dan
.Dan
