Please Help Me Choose Next Performance Upgrade!!!
Old Aug 26, 2000 | 11:14 AM
JDarty6173's Avatar
Question Please Help Me Choose Next Performance Upgrade!!!
Ok, you can see from my sig below what I have done up to this point..And everything in my "soon to be" catagory will be completed on Monday...
Now this is what I need some opinions on..
For my next major step I am either going to
1) Get custom ported and polished heads w/mutliangle valve job + custom cams from Houston Performance
OR
2) Upgrade to 4.10 gears and go with a Protorque torque converter
So I basically what I'm asking is should I go for more power now with the heads and cams or should I make better use of What I already have with the gears and torque converter?
Maybe some pro and cons of both would be useful here, because I'm really at a loss at to where to go from here..Also the Heads and cams would be accompanied by forged pistons as well..
Thanks in advance everyone.
JDarty6173@aol.com
1999 F-150 5.4 Lariat 4x4 w/ORP 3.73 gears
Current Performance Mods:
*MAGNACHARGER Supercharger
*Superchip
*K&N FIPK
*Edlebrock 75mm Throttle Body
*Granatelli MAF
*JBA Headers
*Flowmaster 40 DeltaFlow with duals @ 45Degree angle
Mods Soon to Be:
*Pro-M 80mm calibrated MAF+Filter
*Motorsport 24lb Injectors
*Re-Flashed Superchip
*Bosch Platinum +4 Plugs
Wish List:
*Custom Head and Cam Job
*Upgraded Ignition
*Possibly a shot of N2O
*4.10 Gears
*Forged Pistons and rods
Old Aug 26, 2000 | 01:42 PM
Way2Big's Avatar
Thumbs up
JD-
I would go with the gears and torque conv. change. Cost would be the main reason, for me at least. I have similar plans down the road but I'm going to wait till it breaks. Doing the heads and pistons is pretty labor intensive and if I was going to go that route, why not yank the whole engine out and make her a little "bigger". Just my .02 worth of course!
Good Luck!
'98 EB Expy
5.4L 3.73 LS
Trail.Tow & Skidplate Pkg.
DA MODS....
** Pro-M 80mm MAF w/Filter & SC cal.
** WMS Velocity Tube
** 75mm Edelbrock/BBK TB
** Magnason/Eaton M90 Supercharger
** Autometer Boost Gauge w/ A-pillar mounted pod
** Cust. Prog. Superchip
** JBA Jet Black Ceramic Coated Headers
** Stage 8 Locking Header Bolts
** Gibson Sweptside Catback
** IPD Rear Anti-Swaybar
** Bilstein Shocks
** Manik Grill/Brush and Rear Taillight Guards
** PIAA 520 Foglights
** Clear Corner Lens
** Stull Billet Grill and Bumper Insert
** Ford Molded Mud Guards
** Ford Hood Guard
** "EXPEDITION" Receiver Cover
COMING UP NEXT IN THE FUTURE....
** Brembo Crossed Drilled Brake Kit
** F1 Cobra style hood
"Its Sooo Big...Its Gotta to be Blown!"
Old Aug 26, 2000 | 02:45 PM
54regcab's Avatar
Lightbulb
Definetely the 4.10s
You are already getting as much air in the engine as possible with the supecharger.
A port/polish job would yeild the same results as upping the boost pressure on the Magnacharger.
Old Aug 26, 2000 | 04:25 PM
JDarty6173's Avatar
Wink
I like the way you think Way2Big, possibly get it bored out when I have it pulled...Maybe Houston Performance Will even offer a Stroker Kit for the 5.4
Well that's the way I'll proceed, with the gears and Torque converter..
54RegCab, I don't know of anyone who has yet upped the boost on a Magnacharger yet...I talked to Chris at Magnacharger and he said that a smaller blower pulley was not available..He also told me that I could have a custom Blower pulley made by ASP...Has anyone tried this or any other means of getting more boost from a Magnacharger? How about a smaller crank pulley? Chris told me that I could safely run around 8lbs of boost with no problem..
Next question, I even thought about the possibility of 4.30 gears instead of 4.10...So, go ahead and talk me back in to getting the 4.10's...Also where is a good source to purchase the gears? Keeping in mind that I have the 4x4...
Thanks guys
Old Aug 26, 2000 | 07:35 PM
Way2Big's Avatar
Thumbs up
JD-
If Chris is able to get a pulley made for you, let me know. I would be interested it this same mod. We may be able to get it at better price if we can get a group purchase goin'!
Not sure about 4.30's, gas prices are high enough and I'm not sure that there would be a "noticeable" gain from 4.10's.
Thoughts?!
'98 EB Expy
5.4L 3.73 LS
DA MODS....
** Bilstein Shocks
** Ford Hood Guard
Old Aug 27, 2000 | 10:58 AM
JDarty6173's Avatar
Post
When I find out anything more about the blower pulley I'll let you know..A group purchase on that would be great..
I was also worried that switching to 4.10 gears may not be very noticeable..After all I do have 305/70/16 tires so the 4.10's would essentially put my ratio a little over the 3.73 I stated with..Well, time to make a post about that I suppose..
Take care
