5.4l vs 5.3l
Old Aug 23, 2000 | 02:59 PM
faster46triton's Avatar
Post 5.4l vs 5.3l
This has been debated before, time to bring this back up!
5.4l has my bets. Faster, stronger.
Old Aug 23, 2000 | 04:30 PM
michael_hovis's Avatar
Post
CHEVY:
_________________
Vortec 5300
V8 SFI
Block material
Cast iron
Cylinder head material
Aluminum
Bore & stroke (mm)
96.0 x 92.0
Displacement (cc)
5292
Compression ratio
9.5:1
Induction system
SFI
Valves/cylinder
2
Lifters
Hydraulic roller
Cam drive
Chain
Horsepower/kW @ RPM
(SAE net)
190 kW @ 4600
285 @ 5200/
Torque/N-m @ RPM
(SAE net)
325 @ 4000/
427 N-m @ 4000
Recommended fuel (min.)
87 octane
_________________________
FORD:
Triton 5.4L
V8 SEFI
Block material
Cast iron
Aluminum
Bore & stroke (mm)
90.2 x 105.7
Displacement (cc)
5408
Compression ratio
9.0:1
Induction system
SEFI
Valves/cylinder
2
Lifters
Cam drive
Chain
Horsepower@ RPM
(SAE net)
260 @ 4500
Torque@ RPM
(SAE net)
345 @ 2300 or 350 @ 2500
87 octane
______________________________
When I drive, I'm usually in the 1500 - 3500 range. How do Chevy owners drive when peak torque is at 4000? The Triton is a workhorse and Ford sacrificed some mileage to get the torque, I think I can live with that.
Model: '99 F150 Lariat Supercab 4x4 SS Mechs: 5.4L, 3.73 Diff (9.75" LSD Rear, 8.8" Front)
ORP: Skid Plates, LT265/70R17 GY Wrang. AT/S
Group III towing: HD Electrical/Cooling, GVWR 6500# (Extra leaf spring).
Stuff: Step Bars, 4W Disc ABS, K&N filter, 0W-30 Series 2k Amsoil @ 8200 miles, Herculiner
Stock Items That Differ Across F150s: Steel Driveshaft, Oil filter bolted to engine w/ drip guard, 4R70W transmission.
Old Aug 23, 2000 | 05:09 PM
LHM's Avatar
LHM
Cool
I have driven both. My cousin has a 99 5.3 reg cab long box Z71. The Z will haul ***. I think chevy makes up for what it lacks in low end torque with gearing, as well as engine managment. The chevy revs very quickly and is not affraid to wind out gears. I think they are basically tit for tat, with the chevy being a little quicker. Ford is definately the better truck as far as quality, and I would much rather pull my horses with the ford. There is something satisfying about being able to get a 13,000+ GCVWR rig up to speed staying well under 3,000 rpm and it is even more satisfying when you can do it with only 330 cubic inches, of course that's just my opinion I could be wrong.
LHM
2000 F-150 Super Cab XLT 4x4 ORP 5.4liter V8, Towing Package, Rear Slider, Remote keyless Entry,3.55 LS, Black Exterior, Medium Graphite interior, manual shift 4x4. Current mods Gooseneck hitch,Ford Custom Molded Splash Guards, Muth Signal Mirrors, SUPERCHIPS Performance Chip, and Y pipe with duals.
Old Aug 23, 2000 | 09:44 PM
Big Red's Avatar
Post
If you like to go off-roading, you will like the low end torque of the 5.4L it really helps get up steep hills, mud pits, turn big tires, etc. I have a 351W in my current truck and I love the low end torque that it has. The mid range is nice too, just not to much after 4500 rpm but I never go past that even when im racing someone. so who cares about high end power in a big truck. Well if its a lightning I do, thats about it.
92'4X4 Flareside F-150,33" tires, 4" procomp lift, flows, K&N filter, etc.
http://albums.photopoint.com/j/ViewPhoto?u=1073118&a=7924824&p=26818345
Old Aug 24, 2000 | 11:56 AM
fast46triton's Avatar
Post
The Chevy truck engines seem to be car engines.
Old Aug 24, 2000 | 05:00 PM
Post
I agree with that, fast. The compression ratio is pretty high as well, I'm surprised that it can still take 87. The triton almost seems to be a 'diesel' (long stroke) version of a gasoline engine.
Longer stroke in the 5.4, anyways.
[This message has been edited by michael_hovis (edited 08-25-2000).]
Old Aug 24, 2000 | 09:40 PM
BROTHERDAVE's Avatar
25 Year Member
Question
(forget h.p and toruqe)If one 5000 lb vehicle will out accelerate another 5000 lb vehicle don't you think the one that was quicker was more powerful?
faster46 what is the difference between a car motor and a truck motor. the 4.6 in the mustang gt, cobra and the 4.6 in the truck all have the same bore and stroke.
Old Aug 24, 2000 | 11:27 PM
Nitrox's Avatar
Post
Just curious, why would you want to forget about horsepower and torque? Without these two peices of the pie, you go no where, no matter what the brand ... Your post is redundant ...
• 2000 F-150 XLT
• 5.4 LITER TRITON V8
• 4X4 OFF ROAD PACKAGE
• SHORT BED EXTENDED CAB
• BRIGHT RED CLEARCOAT
• GRAY INTERIOR
• AUTOMATIC W / MANUAL 4X4 SHIFTER
• 3" PERFORMANCE ACCESSORIES BODY LIFT
• 33X12.50X16.50 BFGOODRICH ALL-TERRIAN KO'S
• AMERICAN RACING BAJA'S 16.50X9.75 RIMS
• FORD SOFT TONNEAU COVER
• BLACK POWDER COATED STERLING EQUIPMENT NERF BARS
[This message has been edited by Nitrox (edited 08-24-2000).]
Old Aug 25, 2000 | 10:12 AM
25 Year Member
Post
nitrox, i'm courious what part is redundant, I posted 1 time on the subject, metioned h.p. one time, metioned torque 1 time, and used used the word powerful to descibe the feeling. after a chevy spanks you from a stop light do you catch him at the next stop light and tell he can't do that because you have more torque.
by the way, don't i need gas, tires and a whole lot of other thing to make my truck go?
Old Aug 26, 2000 | 01:37 AM
mlaugh's Avatar
Post
Brotherdave Man you just dont understand! OK lets try this race: 1999 Ford f150 vs 1999 Covrette: stoplite to stoplite OK?
On your mark, get set, GO!
Ford________________________
Corvette______________________________win
But now..... which engine would do better towing a 5,000 lb trailer? and dont pick the Corvette either.
Please see your other posts 4.6 vs 4.8
97 F-150 4.6 auto, 4x2, 3.55 LS, WMS Velocity tube, Dynomax Super Turbo exhaust with Echo tube.
Oh yeah, it's Oxford White with crome wheels, Legacy shell & custom grill!
[This message has been edited by mlaugh (edited 08-26-2000).]
Old Aug 26, 2000 | 02:15 AM
nomo's Avatar
Question
michael_hovis-
I don't know about "ALL" the 5.3L trucks, but my boss has a Y2K Z71 and it requires premium fuel just like the LS1-equipped cars.
BrotherDave-
The block is about the only common thing between the versions of the 4.6L engine. The entire "top-end" (TB, upper/lower intakes and heads) as well as the exhaust are all totally different between trucks and cars. Plus, the Cobra has a DOHC engine.
[This message has been edited by nomo (edited 08-26-2000).]
