Synthetic Oil Pole
Mobil 1 Synthetic 5W30
2000 F-150 Super Cab XLT 4x4 ORP 5.4liter V8, Towing Package, Rear Slider, Remote keyless Entry,3.55 LS, Black Exterior, Medium Graphite interior, manual shift 4x4. Current mods Gooseneck hitch,Ford Custom Molded Splash Guards, Muth Signal Mirrors, SUPERCHIPS Performance Chip, and Y pipe with duals.
I use Amsoil Series 2000 0w-30 in the F150, and I use the Series3000 5w30 in my VW Jetta TDI.
I use 10w40 in my BMW r1100r
It's nice to see so many folks using synthetic. I guess it's not snake oil any more!!!
Lube-Direct
New Lubrication Forums
Lube-Direct
Mobil One Synthetic Oil
1997 F-150 XL Flareside 4.2, Auto 3.08, K&N Air Filter, Glass Pack Muffler single in dual out, Superchip, Diehard Security Battery, Cragar Rims, Tail Light Modification
Amsoil Series 2000 0w-30.
Model: '99 F150 Lariat Supercab 4x4 SS Mechs: 5.4L, 3.73 Diff (9.75" LSD Rear, 8.8" Front)
ORP: Skid Plates, LT265/70R17 GY Wrang. AT/S
Group III towing: HD Electrical/Cooling, GVWR 6500# (Extra leaf spring).
Stuff: Step Bars, 4W Disc ABS, K&N filter, 0W-30 Series 2k Amsoil @ 8200 miles
Stock Items That Differ Across F150s: Steel Driveshaft, Oil filter bolted to engine w/ drip guard, 4R70W transmission.
98 Nascar Edition
Homepage http://www.freeyellow.com/members8/jackhel/index.html (I have some serious updating to do to my site.)
Powerdyne Supercharger, Superchip, Autometer Boost Gauge and Pod, K&N Filter, TransGo Performance Shift Kit, Dynomax Ultra Flow Exhaust, Taylor 8mm wires And Bosch Plantinum Spark Plugs, Gutted MAF, 4.10 Rear End Gears, 275/55-16 Tires, XTRA Bright Halogen Lights, Amsoil Series 2000 Synthetic 0w-30 Motor Oil, 2 inch rear lowering shackles, G-Tech Pro Series II, Bedliner, 100w driving lights, Cobra 75WXST CB Radio, Wilson Little Wil Antenna, and some other stuff I can’t remember.
98 Nascar Edition
I saw a Consumer Reports article. They took a bunch of New York taxi cabs and tested them using both synthetic and regular oils and 3000 and 5000 mile change intervals. They reported that there was no difference in engine wear between synthetic and regular oils and no difference in change intervals after tearing the engines down and checking them out. I personally use Valvoline 5-30 every 3000 miles. I'm going to switch to synthetic in my transfer case and I just had my tranny oil changed by Ford who of course put in Motorcraft Mercon. Just my 2cents.
Red '97 F-150 SC 4x4 off-road, 16" rims instead of factory 17"'s(borrowed from old '97 reg cab), BFG 265/75 16 all terrain T/A, K&N filter with modified air box, Flowmaster 40 with duals out back, Expedition center console, 3" rear seat lift, after market stereo seen at HTTP://members.sounddomain.com/red97,
Regarding the NY taxi cab test...seems to me that those results are only valid if we drive our trucks like the taxi cabs. I shut my engine off every night, it cold soaks, and is cold-started the next morning. Aren't the cabs run virtually 24 hours a day? Also, if synthetic is better, I'd expect the advantage to show up after a hundred thousand miles. I wonder how long they ran the taxis?
Danny
'98 F-150 Std., RC, SB, 4x2, 4.2L, 5-sp, 3.08, AC, speed control, rear slider.
Mods: Mobil 1 engine oil, Red Line D4-ATF trans fluid,
Edelbrock IAS shocks, 50 Series Flowmaster,
K&N with airbox mod, Perma-Cool electric radiator fan,
Superchip, ASP underdrive pulley
[This message has been edited by gaudenti (edited 08-16-2000).]
Danny
valvoline synthetic 5w-30. Its all good (most oils that is) as long as you change it and the filter every 3000.Its funny watching people defend their oil as the best.....like their life depended on it. Just keep it clean.
98 F250 LD 5.4 dual exhaust, K&N, Big tires
LE Synthetic 5W30
2000 F-150 XLT Sport, Silver 4-door Supercab StyleSide
Short Bed (Only way to fit in the garage)
17" Sport Wheels with BFG tires, 3.55 R, 4.6l V8, Auto (First one in 20 years)
In-Dash Single CD Player, 60/40 Split bench dark graphite
Mods So Far
Fumoto Drain Valve, K&N Filter, Gatorback Spray-In Bedliner,
Llumar ProShield Window Tint, WMS Velocity Tube
Future Plans
Superchip, Upgraded Speakers/Stereo
FlowMaster Exhaust, Nerf Bars
Mods So Far
Future Plans
