Porting aluminium question??
Old Aug 16, 2000 | 04:37 PM
Way2Big's Avatar
Question Porting aluminium question??
Hey guys,
I was needing to know what types of "attachments" I would need for porting out aluminium. I have a Dremel at home and I was wanting to know what I would need to remove material and polishing it up. Thanks!!
'98 EB Expy
5.4L 3.73 LS
Trail.Tow & Skidplate Pkg.
DA MODS....
** Pro-M 80mm MAF w/Filter & SC cal.
** WMS Velocity Tube
** 75mm Edelbrock/BBK TB
** Magnason/Eaton M90 Supercharger
** Autometer Boost Gauge w/ A-pillar mounted pod
** Cust. Prog. Superchip
** JBA Jet Black Ceramic Coated Headers
** Stage 8 Locking Header Bolts
** Gibson Sweptside Catback
** IPD Rear Anti-Swaybar
** Bilstein Shocks
** Manik Grill/Brush and Rear Taillight Guards
** PIAA 520 Foglights
** Clear Corner Lens
** Stull Billet Grill and Bumper Insert
** Ford Molded Mud Guards
** Ford Hood Guard
** "EXPEDITION" Receiver Cover
COMING UP NEXT IN THE FUTURE....
** Brembo Crossed Drilled Brake Kit
** AAr Cobra style hood
"Its Sooo Big...Its Gotta to be Blown!"
Old Aug 16, 2000 | 08:33 PM
JDarty6173's Avatar
Post
So this is what you and Chris talked about..
Personally I have no idea what you would need, but then again I wouldn't even think of doing a port and polish myself..
I have had some contact with Steve at Houston Performance via e-mailabout getting a port and polish job with a mult-angle valve job..He assured me that they could do a vey nice custom cam job for me also..I will call them sometime in the next couple weeks and get some more specifics..But it looks like maybe another 50 HP or so is possible..
I also told Chris about my plans to go with a set of forged pistons and rods..He suggested I order a set for a Lightning from my local ford dealer..About $50 each he said for the pistons, with the optimal compression for a supercharged application..
So much work to do, so little time (I begin my Senior year of college next Wednesday)
Take care
JDarty6173@aol.com
1999 F-150 5.4 Lariat 4x4 w/ORP 3.73 gears
Current Performance Mods:
*MAGNACHARGER Supercharger
*Superchip
*K&N FIPK
*Edlebrock 75mm Throttle Body
*Granatelli MAF
*Gibson Catback Exhaust
Mods Soon to Be:
*JBA Headers (with Stage 8 header bolts and Bassani Gaskets)
*Pro-M 80mm calibrated MAF+Filter
*Motorsport 24lb Injectors
*Flowmaster 40 DeltaFlow with duals out the back
*Re-Flashed Superchip
Wish List:
*Custom Head and Cam Job
*Upgraded Ignition
*Possibly a shot of N2O
*4.10 Gears
*Forged Pistons
Old Aug 17, 2000 | 01:35 PM
BROTHERDAVE's Avatar
25 Year Member
Cool
what you need to port alum. is a carbide burr. they come in a shapes and sizes. i bought some from rutland tool (800)-289-4787. my tool has an 1/8" shank. i bought tool # sa-51 model 2064-0052 and tool # sc-51 model # 2064-0056. they where about $8 each. As far as buying pistons from the dealer why not go aftermarket - get a better product for a lower price.
Old Aug 17, 2000 | 02:02 PM
JDarty6173's Avatar
Post
Way2Big, I found a port and polish kit at SummitRacing.com for about $30.. Part #SUM-G1060.
You might want to check it out..
As for the pistons, I looked at aftermarket and it was going to cost considerably more..Besides, the Lighning Pistons are high quality forged...Alot better than a have now..
Take care
Old Aug 17, 2000 | 08:06 PM
Way2Big's Avatar
Thumbs up
Thanks for all the input! I thought the the carbide cutter was the right one. But, what do I use to smoothen it all up? Do I use a sanding flapwheel, grinding stones or a abrasive buff? By the way I'm not doing this on my heads. Thanks!
'98 EB Expy
5.4L 3.73 LS
DA MODS....
** Bilstein Shocks
** Ford Hood Guard
** F1 Cobra style hood
Old Aug 18, 2000 | 09:39 AM
25 Year Member
Cool
use a dremel part no 407 with a part no. 408 sanding wheel. i dont know what you are porting, but i used the carbide cutters and sanding drum to port match a 65mm throttle body to the intake on a 5.0 mustang. i also used it to port match a accel superram for my firebird. for small jobs like this it should work fine. for me, flapper wheels did nothing. i would not waste my time polishing it to a shine. what are you porting?
