engine treatments
Old Aug 14, 2000 | 07:54 PM
matt68's Avatar
Post engine treatments
do those engine treatments that say they quiet lifters and all that really work? All help apreciated
Old Aug 14, 2000 | 09:01 PM
Marv1's Avatar
Post
I had a Acura Legend with an annoying sticky lifter...I used Marvel Mystery Oil and that cured it. Some say Marvel is just snake oil but it worked for me. I have not used it on my F-150 but if I get a noisy lifter I'll give it a try.
'99 F150 SC, 4x2, Oxford white, flareside, 5.4, 3.55 rearend,
bodyside mouldings, Snuglid hard tonneau, K&N dropin, airbox and frsh air mods. Red Outerwears pre-filter.
Duraliner drop-in (gave up on the Penda Nascar). Gibson Supertruck. Ford 2-piece bra. Catch-All floor mats. Image tail light covers. B-Quiet sound dampener in rear of cab. **** pile rug protecting spare tire (Raoul made me enter this)
No door cracks yet at 13K!!!
Old Aug 15, 2000 | 12:17 AM
Matt90GT's Avatar
Post
OHC engines do not have lifters. FYI
Old Aug 15, 2000 | 12:56 AM
Dennis's Avatar
Post
If they don't have something comparable to a push rod's lifter, what do they have instead? There's gotta be something between the cam and the valve, isn't there? What's it called?
Old Aug 15, 2000 | 10:08 AM
Matt90GT's Avatar
Post
The cam lobe. Basically the cam is above the valves and the lobe pushes the valve down. The valve spring keeps tension on the valve and in contact with the valve lobe.
That is basically an OHC engine with the cam above the valves.
On the 5.4 and 4.6, it is an OHC engine, but the cam is next to the valves. So you have rocker arms also. So the cam pushes up on the rocker arm, then the arms pushes down on the valve.
[This message has been edited by Matt90GT (edited 08-15-2000).]
Old Aug 15, 2000 | 09:58 PM
frog's Avatar
Post
I used to think the additives worked. But our company vehicles are on the road from 100,000 to 150,000 miles with no additives. Oil changes are done at 5000 miles. The oil has been tested and is shown to be just fine at 5000 miles. Ford requires 5w/30 and that's all that's put in our engines. Now that I have a new expedtion, the oil changes are done at 4000 miles with 5w/30.
good luck
