header+4.2L
Old Aug 10, 2000 | 08:53 AM
road.rage's Avatar
Question header+4.2L
Does any know if there are any headers made for the 4.2L engine?
F150 4x2 4.2L 5-speed XL
SmittyBuilt:Brushguard
Nerfbars
Tires:Micky Thompsons Baha Radials MTX 285/75/r16
Vent visor:Bug Guard
Window vents
Hypertech:Superchip
Jacobs Ignition Milage Master,Jacobs Super conductor Wires
Flexlite 150 electric fan
fabtech 3" front lift coils.
Trailmaster 2"lift blocks
Add a Leaf spring
Monroe sensatrack: Front/rear shocks
4.10 gears
Pioneer audio single disk tuner/cd
Planet audio speekers
Billit shift ****
Window Tint
Wolf bench seat contractors consoles
Cab clearence lights
Xenon sport flares
Reese frame hitch
Blue wire loom
Redline Synthetic:5w30 motoroil,Atf trany fluid,75w140 gear lube
Hellwig rear sway bar
polyurithane upgrade endlinks front swaybar
pilot fog lamps
vortecs free flow exaust
Swiss Camper top
Old Aug 10, 2000 | 04:52 PM
lightningcrashz's Avatar
Unhappy
It would be nice I could say yes and I have them on my truck but unfortunately headers for the 4.2 do not exist yet. It seems like all the aftermarket performance companies are taking their sweet time about developing products for the 4.2.I think they don't realize how big of a market they are missing out on. oh well.
pioneer cd,cadence ultradrive amps,eclipse mids,tweets&subs,rest is stock for now 2000 black F150 4x4 sport v-6
Old Aug 10, 2000 | 06:19 PM
f150freak's Avatar
Post
The answer is NO and YES. For the 4.2L specifally there is not a set of legit headers, BUT the 4.2L sister engine the mustang 3.8L does have a set of headers! The only problem is that the 3.8L headers do not have the O2 sensor hole in the passenger side header(bummer ain't it?). Although in the near future I want to buy a set and have them modified by welding an O2 bunge into the header. When I do I will try to keep you posted.
Also road.rage I notice you have most of the same performance mods I have. I was wanting to know how it runs with the 4.10's?
99 F-150 4.2L
True duals W/Magnaflows
Jacobs Ignition
K&N filtercharger
Custom programed chip
throttle body spacer
ported&polished throttle body
ported mass air flow sensor
Black Magic electric fan
[This message has been edited by f150freak (edited 08-10-2000).]
Old Aug 11, 2000 | 08:36 AM
road.rage's Avatar
Cool
F-150freak
The 4.10 perform very well I tow a 3500lbs trailer up in the smokie Mts. and have plenty of power.
??? Throttle body spacer, ported mas air flow senser ported and polished throttle body , where did you get these or if you modified them yourself how.
Nerfbars
Window vents
Hypertech:Superchip
Add a Leaf spring
4.10 gears
Billit shift ****
Window Tint
Xenon sport flares
Reese frame hitch
Blue wire loom
pilot fog lamps
Swiss Camper top
Old Aug 11, 2000 | 04:59 PM
REGULATOR's Avatar
Cool
WOW,
I think I need to talk to both of you.
F150 freak Ditto on the above ? including the fan.
Road rage, please tell me you have some
pics of your truck? ALSO I have been looking at the MTX radials in that size, Please tell me more... Pics would be great ,you can email them if you want. <A HREF="http://home.earthlink.net/~cdtackett/index.html" TARGET=_blank> </A>
Y2K F150 4x4 XL Med Torredor Red
4.2 5 speed,AIRAID, SuperCHIP,
3.55 LS, Leer camper shell, bedrug,
Ranchhand Rover Brushguard 2X Off road lights
Tint/alarm/ aftermarket keyless entry/locks
2m radio, CB, 3 Scanners
regulator@f150driver.com
[This message has been edited by REGULATOR (edited 08-11-2000).]
Old Aug 12, 2000 | 08:02 AM
road.rage's Avatar
Post
Regulator,
I don't have any pics yet, But the mtx radials are the best I have ever had smooth ride at 45lbs air will handle 65LBS not to noisey and good handling.
? how do I put pics of my truck in here?
Nerfbars
Window vents
Hypertech:Superchip
Add a Leaf spring
4.10 gears
Billit shift ****
Window Tint
Xenon sport flares
Reese frame hitch
Blue wire loom
pilot fog lamps
Swiss Camper top
Old Aug 12, 2000 | 10:33 PM
f150freak's Avatar
Post
What I did is the spacer is for a 99-2000 mustang 3.8L, and the throttle body and M.A.F. I have a friend who works for a local speed shop he did the machine work on them. I looked forever for legit parts and could not find any so I had to get inventive. Hopefully my intake manifold is next on the machining deck. Last the fan..nothing special about it I just followed the directions. The only thing is it is not connected to the A.C. clutch, for some reason I kept blowin my fuses so I have it on constant run to turn on&off with the ignition.
Old Aug 13, 2000 | 10:49 AM
road.rage's Avatar
Post
F150freak
did you get any noticable gains from these mods.
Nerfbars
Window vents
Hypertech:Superchip
Add a Leaf spring
4.10 gears
Billit shift ****
Window Tint
Xenon sport flares
Reese frame hitch
Blue wire loom
pilot fog lamps
Swiss Camper top
Old Aug 14, 2000 | 12:28 AM
f150freak's Avatar
Post
The throttle body and M.A.F I picked up some lowend power but on the fan I could not feel any diffrence at all. When I did the porting and polishing it cost me about $150.00 ($75.00 each) It should of cost more but my friend gave me a slight discount.
Old Aug 14, 2000 | 03:14 AM
V10 man's Avatar
Post
JBA says that the 4.2L headers will be available soon. www.jbaracing.com
Old Aug 14, 2000 | 04:46 PM
REGULATOR's Avatar
Post
Roadrage,
Do you have any digital pics or a scanner?
If so You can check under several threads that give directions, or Email some to me and I'll see what I can do ( I want them for me anyway)
