hey dragonboy !!
Old Aug 13, 2000 | 03:07 PM
max mitchell's Avatar
Question hey dragonboy !!
I have some questions for you about your intake system; If you can remember or help.
BBK throttle body- part # ? , What was included for the 2000 50-state CARB certification? Did it have the added idle adjustment? Did it bolt on perfectly? Results, Tips, Comments?
Granatelli MAF- was it #75004619-0 ? , What was included for the 2000 50-state CARB certification? Was the mount up smooth with the K&N FIPK ? Results, Tips, Comments?
K&N FIPK- They told me that they do not make or CARB certify a 2000 model yet. Part # ? What did they include for any year certification. Did this unit fit well, mount up to the throttle body and MAF well? Results, Tips, Comments?
What kind of performance did each of these things result in, and which one was most noticeable. Have you had your truck to the dealer since the install; what did Ford think? Warranty, etc. Any help would be greatly appreciated. Thanks in advance.
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
Class III tow/Payload #3/Convenience pkgs.,
4-wheel disc/ABS,Chestnut/Parchment 40/60,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification, Superchip,
Dynomax ultra-flow welded 3" cat-back,
3" exit Y-pipe, Hellwig rear anti-sway bar.
