Error Code HELP!!!!
Old Jan 16, 2002 | 02:20 AM
Boss Ross's Avatar
Angry Error Code HELP!!!!
I am working on my brothers Expy w/the same 5.4 4x4 setup as my truck. The infamous check engine light came on just as the engine started running roughly at idle. I mean rough as a toothless, armwrestling bar maid. We pulled the OBDII codes and they were:
P1131 - Lack of Ho2s11 sensor indicates lean
P1151 - Lack of Ho2s21 sensor indicates lean
These are both Heated Oxygen Sensor codes and I replaced all 4 o2 sensors and replaced the fuel filter, spark plugs and gave everything a good cleaning like MAF, DPFE Sensor lines, fuel injectors and what not. I inspected everything and the "Check Engine" light is still on.
Any REAL mechanics out there that can help?
Old Jan 16, 2002 | 10:50 AM
ssabin's Avatar
These codes are indicating that both banks are in a lean condition.
There is probably unmetered air coming into the engine. Check for vacuum leaks - there's most likely one there somewhere.
Old Jan 17, 2002 | 12:41 AM
nitro94's Avatar
Ditto on the vacuum leaks. Look closely at the PCV system hoses. Have seen several of these lately. They can be hard to follow due to there location.
