302 to 351w Swap
I've got a 1990 F150 4X4 with the stock 302 still in it. Anyone that has the 302 in a 4X probably knows that it is terribly underpowered. Has anyone out there successfully accomplished a stock 302 to a 351w engine swap? I would interested to know how clean the swap is. Are there any big "gotchas"? Any help would be appreciated. TIA
Hey. I've got one lined up for my truck with a blown 351 stroker. In addition to the crate 351, you're gonna need a new computer, as well as headers. Otherwise the swap goes pretty flawlessly. The 302 and 351 are VERY similar. Shouldn't be a problem.
1995 F-150 Regular Cab Flareside w/ 302 V8... Mods: Mass Air, K&N FIPK, Dual Exhaust (no mufflers), Lund Premier Tonneau Cover, Motorsports 9mm Plug Wires, full JL/Kicker/Pioneer system, Autometer 5" tach, Superchip, Precision Gear 3.73s, TD Chrome Diff Cover
Best 1/8th ET: 10.4107 @ 65.9587 MPH
The F-150 Resource Guide
The F-150 Resource Guide-- a site dedicated to 1987 through 1996 F-series trucks.
You'll need another computer, or a switch to a Mass air computer. You didn't state what tranny, if you have the E40d(was new for F-150's that year), you'll need a speed Density computer from a 1990-1995 speed-Density EFI computer. My advise is look for a wrecked harness. I also have heard were the exhuast pipes won't bolt up right, might just be a myth.
I have the 5.0L in my 1989 F-150 4x4 with a AOD and 3.55 gears. It's not underpowered by any means. Of course it's not stock either...
I thought about a 351, to replace my 302 in my 89, I might just build up this 302 and replace the EFI with a carb/intake so I can run a bigger cam. I want to keep my 16mpg, I doubt a 351 can accomplish that...
[This message has been edited by Pastmaster (edited 07-31-2000).]
Yes. I should mention that the underpowered statement was refering to my stock motor.
Thanks for the replies. I probably should apologize in advance for being a Ford novice. I have had my truck for 6 years, and until now, have never thought of it as more than a ride to work. I have some rebuilding experience, but none on anything larger than a Honda Accord (about ten years ago).
Having said that... Is there somewhere out there that I can look up engine and tranny codes to find out exactly what I've got here?
My ride isn't broke, so I'm able to build one the way I want it. I hope to not wear out my welcome here, but I'm probably going to need a good deal of advice throughout the project. So, thanks in advance.
Hi 90F150
I had a 90 till 95. Changed engine & if anything, it got worse. If you make this move you'll have to change the electronics or do away with it. By the way, next was a 95 302 & it ran pretty good. It had MAF.
97 Lariet-sc-4.6-4x off road-auto-3.55 LS-
superchip-K&N-3"
pvc air box mod-Granetelli MAF
superchip-K&N-3"
302 to 351w problems
I just did a swap in my 90 f150. Took the tired 302 out and put a 351w in out of a 88 f250 that had a c6. My problem is that it took out the torque convertor and the front pump. I took the truck to a local ford dealer ship 4weeks ago and here is what the did. Put in a new front pump and convertor and once again they wnet out in a mtter of minutes. Took the tranny out and rebuilt it and it did it again once again the removed it and said that the flywheel was wrong, I used the flywheel that came with the engine, so they put a 302 flywheel in it and the tranny work great but now theres a vibration and they said I either need to swap engines or replace the tranny. Has anyone had this kind of trouble doing this swap? Forgot to mention my tranny is a AOD.
