V8 - 4.6 or 5.4
Old Jul 21, 2000 | 09:26 PM
Duntleyp's Avatar
Question V8 - 4.6 or 5.4
A dumb question for you F150 fans - is there any way of determining from the outside if an F150 with the Triton V8 plaque is a 4.6 or a 5.4? Tail pipe size? oil pan? Just curious. Thanks
Old Jul 21, 2000 | 11:06 PM
gearmanx17's Avatar
Question
Look at the size of the differential housing. I think 5.4L vehicles have the bigger 9 3/4" diff. You can noticibly see the 9 3/4" diff. is larger (if you view the vehicle from the rear). Come on 5.4L owners! Is this correct for 97 & 98 too?
1999 teal blue f150 s/c
4.6l, xlt, 3.55 L/S
Tow pkg., rhino liner, engine block heater & hard toneau cover. single c.d.
255/75 r16 Generals-owl
Old Jul 21, 2000 | 11:08 PM
GEARS's Avatar
Post
If you're sharp, and happen to look at the rear diff. You can spot a 5.4 due to its massive diff. casing. The one on a 4.6 {8.8} is good beefy unit, but the 9.75 diff of a 5.4 looks like somethimg off a 1 ton.
Old Jul 21, 2000 | 11:47 PM
DarnEFNET's Avatar
Post
Every 5.4 I have seen has the larger rear axle, the 4.6 axle is easy to spot, its the same axle that is behind the V6
Old Jul 22, 2000 | 08:55 AM
2000regcab54's Avatar
Post
Here's how you can tell on my truck.
[img]//albums.photopoint.com/j/View?u=688831&a=5017225&p=24677089&Sequence=1[/img]
[img]//albums.photopoint.com/j/View?u=688831&a=5017225&p=21112778&Sequence=7[/img]
2000 reg cab sb XLT 2WD
5.4
silver
3.55 LS
4 wheel antilock discs
Superchip Flip Chip
K&N
17x8 TSW Trackers
285/60-17 Pirelli Scorpion Zeroes
Downey SST Tonneau
Gibson Stainless Split Rear Catback
2 inch drop shackles
Ford factory fog light kit
[This message has been edited by 2000regcab54 (edited 07-22-2000).]
