water leaking from under truck
More than likely it is condensation from the AC. Mine seems to drip quite a bit, more than most vehicles it seems, but I'm taking it as normal. Our exhaust also has a "weep hole" which removes condensation from our exhaust system. As long as it isn't neon green antifreeze, I wouldn't worry. Does that seem about right to our mechanic friends?
00 supercab, 5.4,4x4, stay up too late on this site!
Donald,
Jumpn is correct ....... I would be concerned if you didn't see clear water dripping under your truck after using the air conditioning. Your condensation drain-off would be clogged.
Dunbarton "The Middle Aged Kid" '99 XLT SC SB 4x2 4.6 auto 3.55 ls The occasional Z-71 Eater! Wedgewood & Denim, SuperChipped, Airaid FIPK, HD electrical and cooling, power seat, Rhino Liner, Extang Classic tonneau cover, Mobil 1. Man, I got it all! (New Jersey)
