Stupid question??
When looking at performance engine parts and accessories for my 4.6L 5-speed, can I consider the use of parts intended for the 4.6L Mustangs?...or are they different engines entirely...sorry if this is a dumb-*** question.
actually a good question ,,,i'm curious on that one myself?
But i'm pretty sure they are the same engines. I suspect that they have different heads, cams, and intake... the internals are probably the same (crank,pistons, bearings...etc)
mustang 4.6 =dohc
truck 4.6 =sohc
also you are right cams are different as well as the entire intake manifold. Most sensor positions are different and of course the mustang engine pcm has a completely different pcm program so most parts are not interchangeable
truck 4.6 =sohc
Originally posted by PKRWUD
Correction:
Cobra 4.6 = dohc
Mustang & Truck 4.6 = sohc
Take care,
-Chris
Correction:
Cobra 4.6 = dohc
Take care,
-Chris
Internal components are interchangable, external components may be interchangeable, unless they are specific to the vehicle, like headers (all headers are engine and vehicle specific), or other items designed for clearance/fit on/in a specific vehicle. Your best bet would be to ask the seller if the parts you are interested in are "vehicle specific".
Take care,
-Chris
Take care,
-Chris
