4.6L Valve train noise
Old Dec 18, 2001 | 10:44 AM
davidzog's Avatar
When I start my new Supercrew in the morning, the valve train noise is almost frightening.....help...
I am using a Motorcraft filter FL820S and Motorcraft 5w20 oil...I plan to change to Valvoline, now that it is available....
Any ideas???? What about switching to a 5w30, maybe a synthetic, or Mobil1 0w30....
All suggestions will be greatly appreciated.....thanks
Old Dec 18, 2001 | 02:25 PM
BConehed's Avatar
Cool
A lot of guys on this board are going to tell you to use a synthetic, however, I like Castrol 5W30 in my '99 4.6. My engine also makes an unusual noise for the first few seconds after it is cranked, and I haven't taken the time to look for the problem, but I don't think it's in the valve train. It sounds more like a metalic popping sound, possibly the injectors firing. I only noticed it recently, since the weather has cooled off somewhat. Let us hear from you if you determine what your problem is. Good luck.
Old Dec 19, 2001 | 09:36 AM
davidzog's Avatar
THanks for the reply... I am thinking about a switch to 5w30 just to see what happens.....if anything!!
Old Dec 19, 2001 | 11:56 AM
Eduk8er's Avatar
What does your owners manual say to use? Mine says 5w30 already.
Old Dec 19, 2001 | 01:27 PM
davidzog's Avatar
MY owner's manual specifically states 5w20 under all driving conditions....there is no guessing or compensating for the desert or Alaska or anything....
My truck is a 2001 Supercrew with a 4.6L v8...
