Towing Capacity
Old Nov 21, 2001 | 07:26 PM
Shannon B's Avatar
Post Towing Capacity
Has anyone actually pulled a 5th wheel with their F150? We are seriously considering purchasing one just for this reason. We have heard good things and this site has been very useful for research. But, I have yet to find someone that has pulled anything with theirs. We have a 22' 5th wheel (6500Lbs empty) that we want to pull with it and want to know if anyone has had problems with power, especially pulling up hills.
Old Nov 21, 2001 | 08:17 PM
Greg Mc's Avatar
i think someone talked about this before. go to the tow and hauling forum and do a search for 5th wheel towing. you'll probably find some past discussions.
Old Nov 21, 2001 | 08:57 PM
Ford4ever's Avatar
It will tow it, stopping may be a problem though. If you check the rating on the f-150's door sticker your trailer, loaded would probably exceed the rating. I would go with a larger truck at least an f-250. Of course the dream truck would be an f-350 dually diesel.
-Jon
Old Nov 21, 2001 | 09:40 PM
FordRaceFan's Avatar
I have a F150 with a 5.4. I pull a 26 ft. travel trailer it's around 6,000 lb. empty and I pulled it all over the country across I 10 LA to Fl. I 70 Md. to I 15 home let me tell you the Rocky's that a little hilly truck brakes were fine trailer has brakes got 9 miles to the gallon with the tow package it's got a 3.55 rear with the overdrive off it coast down hill just letting off the gas little braking hope this help BUT I rather have that 350 ford4ever talked about
Old Nov 21, 2001 | 11:51 PM
George Eh's Avatar
Hi Shannon if your 5'ver weighs 6500# empty for sure you will be over the GCWR when its loaded. The GCWR for most of the F150's is 13000# and the GVWR of my F150 is 6300# so theoretically if my truck is maxed out I could pull 6700#. My 150 also has a payload capacity of 1850# which doesn't take long to max out when you add up pin weight, people weight, tools, gas, etc. Even the options on your truck have to be added to your payload cap. Having said all of the above I pull a 21' 5'ver but it has a GVWR of 4300# and weighs 3300# dry with a pin weight of 600# quite a bit less than yours. Maybe your weight is incorrect it seems high but then maybe you have a slide out, mine doesn't. I'd suggest having your trailer and truck weighed, if you are at the max or over your GCWR I think youb would be better off with a heavier truck. Good luck
