EEC-IV or MCU Engine Computer Control System
Old Nov 21, 2001 | 08:54 AM
Chappy's Avatar
Question EEC-IV or MCU Engine Computer Control System
Need a question answered. Which dose my 1993 Ford F150 have?? EEC-IV or MCU Engine Computer Control system??
Chappy
Old Nov 21, 2001 | 09:39 AM
Pickup Man's Avatar
If I emember correctly, it has the EEC-IV.
Old Nov 21, 2001 | 09:45 AM
Chappy's Avatar
Do you remember where it is located??
Old Nov 21, 2001 | 10:42 AM
signmaster's Avatar
Drivers side firewall. Just look for the harness that plugs into the computer.
Old Nov 21, 2001 | 11:05 AM
PKRWUD's Avatar
EEC IV is correct. Just to elaborate, the ECM itself is located behind the drivers side kick panel, behind the e-brake pedal assembly. The self test diagnostic connector should be stuck inside a housing that is attached to the drivers side fender, near the firewall, under/next to the hood hinge. Look for a house shaped connector and a single wire connector.
Take care,
-Chris
Old Nov 21, 2001 | 11:52 AM
Chappy's Avatar
Sounds Great. I am assuming that Ford uses 3 code ID. Also I have a Actron III tester. Is this a good tester. Are there other one that are better??
Old Nov 21, 2001 | 01:13 PM
hobbit's Avatar
Scan Pro
Hi,
I have a scan pro code scanner for the EECIV system I used on my 95 explorer. It works on most fords, lincoln and mercs from 1983-1995.
Its up for sale in the classifieds for $20 if anybody is interested.
The scan pro works great and was featured on Shadetree Mechanic.
It paid for itself in savings from an avoided trip to the dealer when I had a check engine light come on. Turned out to be nothing but would have cost me an hours labor + to get the code read at the dealer. Great tool to have around.
Hobbit
Old Nov 21, 2001 | 01:25 PM
PKRWUD's Avatar
There are always better scan tools. My OTC Mindreader set me back close to $500. It's better than many, but not as nice as some. I'm not familiar with the Actron III, but I'm sure it will be fine. Your truck will either have 2 or 3 digit codes. Make sure to do both KOEO and KOER.
Take care,
-Chris
Old Nov 22, 2001 | 01:03 AM
signmaster's Avatar
Chappy,
I have one of the Actron readers and it works fine. It's a basic reader but that's all you need in most cases.
Old Nov 23, 2001 | 11:06 AM
Chappy's Avatar
Thumbs up
Use my reader and it worked did both KOEO and KOER Test. It helped me alot. This board also helped me thanks to all that replied.
