Noise from Engine compartment
Old Apr 4, 2000 | 10:19 PM
GregCS's Avatar
Post Noise from Engine compartment
Hey guys,
I just bought my 98 F150 XLT 5.4L on 04/01/00. The next morning I started to hear a noise that had the same symptons as the dreaded Piston Slap, but I was unsure of what piston slap sounds like.
So here are 4 sound files of my engine... now that I have had a chance to actually get under the hood and listen I am doubting it is the Piston Slap. It almost sounds like pulley bearings or something like that squeaking. Before I only listened from in the cab or with the Window down. That would be great if that is all it is.
Ok 2 sound files can be downloaded in Zip format: http://www.geocities.com/gmanhere79/noise1.zip
http://www.geocities.com/gmanhere79/noise2.zip
http://www.geocities.com/gmanhere79/6.zip
http://www.geocities.com/gmanhere79/7.zip
What does it sound like to you?
It isn't the piston slap noise is it?
Thanks in advance!!!
[This message has been edited by GregCS (edited 04-05-2000).]
Old Apr 5, 2000 | 10:27 AM
GregCS's Avatar
Post
Ok... the more I listened the more this thing sounds like a pulley on the front of the engine. I can't tell which one, but I believe it is definitely not piston slap now that I have been able to get under the hood and listen to it much closer now.
It is what I would call squeaking of some sort. Anyway, from inside the truck it definitely sounded different.
I am starting to feel a little better that it sounds like a squeak coming from a pulley or something.
Still... tell me what it sounds like to you.
Thanks!
