fuel pump?
Old Feb 19, 2000 | 08:53 AM
fordfan's Avatar
Question fuel pump?
Hey everyone, here's my problem. Every once in awhile, while driving, my truck will stall as if it ran out of gas. Then it just starts up again and keeps going. Does anyone have any ideas? I've been told it could be the fuel pump or computer/electrical problem. Any advice is appreciated.
1989 F-150 XLT LARIAT 4x4 4.9L I6 5 speed manual tranny 3.55 gears K&N FIPK 3" Flowmaster.
Old Feb 19, 2000 | 05:10 PM
Pastmaster's Avatar
Post
I would start with the fuel filter. 89's have 3 pumps, 2 in each tank and a third hi pressure pump, although 300's may have just 2 pumps.
You might have someone check your fuel pressure checked, just to be sure if it is the pump. Otherwise, you should clean your Throttle body, and have you fuel injectors pressure cleaned. This is almost manditory on early efi's like ours.
toydestroyer1@yahoo.com
"Sleeper"
1993 F-150 302/e4od/355 Limited slip. dual exhuast w/o mufflers, 2 1/4" pipes, Echo Tips, Summit Racing headers, accel plugs/wires(8.6mm)/rotor/cap, hypertech powermodule, 4 degree advance,Blaster Coil,MSd 6A Ignition, TPS Mod,hopefully roller rockers in the future,possible 4:10 gear swap 5% dark tint, Ford Bed mat, Bundy Chrome Drop bumper, Wrap-around bug deflector, 2-tone tan/brown. Alpine cd player and Pioneer speakers, with tweeters No room for anything else.
1989 F-150 XLT 4x4 Future 300hp engine build!
2000 Superduty CrewCab v-10, auto,2wd.
Old Feb 24, 2000 | 10:15 AM
kmmon1's Avatar
Post
past master is right try the easiest things first. Check fuel pump. But a very common problem on alot of fords is the fuel pump relay. It is a small square black box that unplugs from the wires. It can be located in the car usually under one of the seats or it should be under the hood mounted on on of the fenders somewhere. You should here it click when you turn on the key everytime.
1998 F150 XLT extra cab white,4.6 with off-road package
tint,rhino-lining, white face gauges, clear front marker lights, stull billet grille
16" lariat 5 stars with dunlop radial rover
285/75/16
Old Feb 24, 2000 | 07:35 PM
fordfan's Avatar
Post
Thanks guys. I appreciate the advice. I'll let you know what happens.
