2000 Lariat 4x4 Alternator Output
I just recently purchased a 2000 Lariat 4 x 4 with the ORP and Trailer Towing Package. On my sticker I recieved a credit for the Heavy-duty Alternator. What is the output in amps of the heavy-duty model (which I do not have) and the standard output. I am looking to add some auxillary lighting soon.
The heavy-duty alternator puts out 130 amps. And you should have the heavy-duty alternator. The credit is because the heavy-duty alt. is part of multiple packages. When you added the tow package you were effectively being charged a second time for the heavy-duty alt., therefore Ford gave you a credit. So you do have the 130 amp alt.
1999 Lariat SuperCab Flareside, Amazon Green with Silver trim, 5.4L, 4x2, 4 wheel disc/ABS, 3.55 limited slip, towing package, fog lamps, sliding rear window, captains chairs, keyless entry with alarm, spray-on bed liner, bug guard, and K&N. http://www.csc.calpoly.edu/~bfriesen/truck.html
Freezers right you have it. I saw that on a sticker recently and it confused me too. But I figured it out finaly with the help of (gulp) a salesman.
Hey.. what does the regular one put out?
97 F-150 SC Lariat, Styleside, White over Gold, 4.6L (Windsor), Automatic, 3.55 rear end, electronic 4X4, w/ every option of Lariat and ORP packages except the 17" wheels (I even got the OR decals now!) MOD's so far: K&N air box mod, Gibson Super Truck, clear Bugflector II, Leer TSC 600 hard cover, Bridgestone Dueler OWL ATP 265/75 R-16's, TrailMaster Invader N7 shocks, Smittybilt step bars, Ford moulded mud guards, "White-white" head lamps, Cloud Rider Design's SS Grill and bumper opening, Bosch Platinum + 4's, Hayden 30K+ Tranny Cooler,Class III Reece load distributing hitch system, full wiring including trailer battery charging system, Escort Sensor II Brake controller, Superchip
I remember hearing something different regarding the HD alternator, that only one is available for the '98+ year F150's. I read it in an old digest, so don't hold me to it. I believe the rating is 110 amps.
'99 Lariat Supercab 4x4 SS
5.4L, 3.73 Diff (9.75" LSD Rear, 8.8" Front)
ORP: Skid Plates, LT265/70R17 GY Wrang. AT/S
Group III towing: HD Electrical/Cooling, GVWR 6500# (Extra leaf spring).
Step Bars
4W Disc anti-lock brakes
K&N filter
Stock Items That Differ Across F150s: Steel Driveshaft, Oil filter bolted to engine w/ drip guard, 4R70W transmission.
Step Bars
K&N filter
