Dyno Testing
Has anyone done a dyno test on Airaid, K&N, Velocity Tube, Power Spacer, or any othe mod?
(Not including Superchip)
99 XLT 5.4L Regular Cab 4x2 120" Wheelbase 4 wheel disc brakes/ABS 5 star larait style wheels Toreador Red/Silver 3.55 gears 255/70/16 OWL Delta toolbox, Ford Running Boards, Ventshades, Bugflector, Bullrings, Donnelly compass mirror, 2" Rear drop.
Eclipse 5340 cd player
Memphis ARCS50 component speakers w/tweeters mounted flush in the door panels (excellent sound)powered by a Sherwood 35x2 RMS amp
Kicker ZR360 for the 2 Audiobahn AWC10 subs
regcab54@sc.rr.com
regcab54@sc.rr.com
I just got home from a dyno test and mine is as follows.
Rear wheel horsepower is 235 hp. at 2,530 rpm's
I was told that there is a 20% loss through the drivetrain so the flywheel would be app.282 hp. I don't know if that is 100% true or not.
torque at the rear wheel is 700 nm / 182 ft. lbs. at flywheel 286.4 ft. lbs. at 2,660 rpm's
My truck feels like a different truck.My 0-60 is 7.37 now. We had to put in a flip chip and we went back four times after the dyno to fine tune the truck so I don't have a final dyno test, we ran out of time.
99 Black F150 4x4 4.2
Powerdyne SVO BD11-a Supercharger
24 psi.high flow fuel injectors
Boost gauge 30"HG-20PSI A piller mount
K&N air filter
True dual exhaust w/Flowmasters(2 1/2 in. pipe)
custom programed Superchip(Feb. 7th.)
All black factory sport package.
Rhino Liner
GTO smoke headlight&tailight covers
limo tint
Mods. to come 4.10gears
K&N air filter
Rhino Liner
limo tint
Yes, manual transmissions have less power loss than an automatic, hence will put more power to the rear wheels. Generally speaking, a manual transmission has a 17% power loss through the drivetrain and an automatic is about 20% (AODE style trans). C6 automatics can have power loss figures upwards of 25%.
HotRodSix
'98 STX Flairside 4.2L
Best 1/4: 16.26 sec. @ 84.4 mph
Dyno: 180 rwhp / 228 ft-lb
HotRodSix
XanMan,
WOW! Sounds lke you got about $10,000 worth of mods??
Why the heck didn't you buy a F150 with the 5.4???????
Sounds like some people are getting 0-60 as fast with only a cheap intake mod and a Superchip.......
Heck, I think one guy has a Navigator that can hang with you!
Just curious why someone who is OBVIOUSLY into HP and mods didn't start out with the bigger engine??
"There's no replacement for displacement!"
-Lingenfelter
Rand
-Lingenfelter
Rand
