gas line removal tool
I read the post on changing your gas filter and it said you need a gasline removal tool. what are these and where do u get them and how much $$ ?? Do u need them on 4.6 v8
thank you
thank you
Hi, you can get them at any auto parts store for a few dollars for the kit (5-6 different sizes)
f-150,xlt,ext.cab,2wd,5.4,3.55ls,trailer tow,capt.chairs,6-cd changer,power everything,sliding rear window,
mods.- hand made fresh air tube (k&n style), k&n filter,bug shield,more to come g-a-r-o-n-t-e-e-d
They work very well...but expect some fuel leakage (keep your face clear). Both the 4.6L and 5.4L use them.
2000 F-150 XLT, 4x2, 5.4L Supercab, Styleside, Black with silver two-tone, 3.55, class III towing package with heavy duty cooling package, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, Pendaliner bedliner, K&N air filter, rubberized undercoating, cabin filtration system, Bugflector II, 5W-30 Mobil 1, engine build 10/4/99
I bought mine at Auto Zone but I have also seen the package at Pep Boys. I'm sure any parts store can fix you up. The tools are round plastic or metal flanges that fit over the gas or A/c lines the release the tabs that hold the line in the filter or a/c fitting. Cost was arount $10.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Magnecor 8.5mm wires, Bosch Plat +4s, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs
Actually I believe it was after the 89 year...I don't need the tool for my 89, but I get pretty pi$$ed while trying to get my 93's off...
I didn't know about the clips when I tried to change the filter the first time!!!! $381, and new fuel lines later the mechanic at the Ford dealer sold me an extra one he had for $10. Since then, the Chilton manual is very helpful!!!!
Red 97 F-150XL SC,SB,4.6 pinger, 3:55ls, tow pkg.,Rhino Liner, K&N Filter, Smittybilt Nerfbars.
