Larger oil filter wanted
Old Oct 11, 2001 | 07:26 PM
GCOLE's Avatar
I would like to use a larger oil filter on the 5.4. Does anyone know of a replacement that is physically larger than stock filter?
I do not want to install a dual system. Thanks.
Old Oct 12, 2001 | 12:44 AM
BeastRider's Avatar
Why do you want a larger filter?
Old Oct 12, 2001 | 06:09 AM
msparks's Avatar
Our filter is metric. Therefore there are no other larger filters that would fit it.
If you want a larger filter you will need to get a remote kit. These have an adapter that hooks up to your filter area then you can mount the filter away from the engine. I believe most of those can take the old ford FL1 or the fram PH8 or equivalent.
That should get you about twice as much filtering capacity as you have now.
BTW, I don't understand why ford uses such a small filter on our trucks that hold 6 quarts. Really doesn't make much sense.
Old Oct 12, 2001 | 05:46 PM
acadianbob's Avatar
agreed msparks. the filter on my V-6 looks appropriate for a Briggs and Stratton lawn mower.
