Engine missing at 40 mph
Old Oct 11, 2001 | 01:12 PM
po68ny's Avatar
My 4.6 automatic sometimes misses at 40 mph. I can't tell for sure if it's the motor or the tranny. My local dealer suggested I change the plug wires but the problem still exists and it doesn't do it all the time. I've had it at the dealer but, of course, they can't duplicate the problem. Anybody else having this same problem?
Old Oct 11, 2001 | 01:18 PM
LIGHTNINROD's Avatar
How long has your fuel filter been inn service?
Old Oct 11, 2001 | 01:28 PM
po68ny's Avatar
The truck has 35,000 on it. Filter changed at 30,000 as well as all other regularly scheduled maintenance done at that time. Engine light does not come on either. Thanks.
Old Oct 11, 2001 | 03:19 PM
It might be just the torque converter locking up?
Dan
Old Oct 11, 2001 | 03:26 PM
po68ny's Avatar
You're probably right. It tends to act up when overdrive kicks in.
Old Oct 11, 2001 | 03:39 PM
Dennis's Avatar
Definite torque converter problem. Can sometimes be alleviated with a tranny flush and fill. Should be a warranty item if the truck still qualifies. If you have the "missing" problem already on the books, it should still be covered if you have gone over the mileage limit.
Old Oct 11, 2001 | 04:05 PM
po68ny's Avatar
Thanks. I really appreciate the assistance. I was at 30,000 and my time on the factory warranty expired one week before this whole thing started. Ford didn't care. Good thing I bought the extended warranty. I'm going to go to a different place for service. Again, thanks.
Old Oct 12, 2001 | 01:24 AM
Dennis's Avatar
Just noticed that I said "Definite" when I should have said, "Could definitely be..." There have been several folks here who had a missing or shudder that turned out to be the torque converter. Several have had good results with the tranny flush and fill.
Old Oct 14, 2001 | 03:03 PM
KYFordFreak's Avatar
Dennis might be right
Sounds like you might have the 40mph shudder that a lot of members here have
Old Oct 15, 2001 | 12:05 PM
po68ny's Avatar
Someone else suggested it's probably the torque converter, which sounds probable. But has anybody figured out this problem for sure? Is Ford admitting to anything?
