Cold Engine, Loud "Belt" Sound
I just picked up my truck from the dealership after having it serviced for this and a few other issues. The solution applied was a change of the serpentine belt. No tsb was noted on the work order. I'll keep my fingers crossed...
go to www.nhtsa.dot.gov/cars/problems/tsb/ and weed your way down through year, make and model prompts. (I found the tsb's using YEAR=97; MAKE=FORD TRUCK; MODEL=F150). At the component pulldown, select "Engine Cooling Systems:belts" and there are three TSB's listed. Go back and select "Engine:Timing gear and chain" and there are two TSB's (one repeated from above category) Hope this helps.
I had the noise from the sep. belt too. I have 42,000 on my 97 so I bought a new motorcraft belt & put it on. It was no fun job either!!!!!!!! The new belt was at least 3/4" shorter plus had different part # than the factory one. No more noise now!!!!!!!....Lariat#1 P.S. Belt cost $26.00 + tax.
1997 Red/Silver F150 Lariat Flareside 3 Dr. SC W/ ORP & Tow Package, Complete Lariat Package Option List ,{APPEARANCE}: AVS Carbon Fiber Headlite Covers, Tail Lite Slots & Door Sill Protectors,Owens Fg. Step Boards, Tinted Windows,Ford 2-Piece Bra,20" Chrome Exhaust Tips,A.R.E Bed Cover Lid,Pendaliner Inner Tail Gate Protector,Zie-Bart Total Paint & Under Coating W/ Sounder Deadener Protection, #1 Ford Truck Plate under glass on Front Bumper, {PERFORMANCE}: 4.6L Auto, 3.55LS, 4-Wheel ABS,Platinum 3 Spark Plugs,K&N Air Filter W/ modified stock air box, Tornado Air Man.,WMS Velocity Tube,Dual Exhaust System,Per. Fiction Carbon Mettalic Disc Brake Pads,Goodyear Wrangler A/TS Tires,55 Watt(replacement) Back-up Lites, Pilot 55 watt Back-up Lites on Hitch under truck,Foglites work W/ Brites On , {STEREO}: Stock In-Dash Cass. W/6 Disc Changer & 4 Stock Speakers, {SECURITY}: Ford Security System W/ Motion Alarm All on same Key Fob, This is LARIAT 1... IN The Great State Of Indiana..........http://hometown.aol.com/terrylariat1...page/auto.html A very Proud Member of ...www.f150online.com
this is a common problem with the 4.6 FEAD belt. Try replacing it with a Goodyear Gatorback belt, Summit racing sells them.
It has good grip. My belt always seemed to glaze on the back side. I think the tensioner is too weak.
birdman
birdman
mine does it to, only 8500 miles.The past few days it has been 0 degrees and it makes a real loud shreiking noise for a second. It squeeks for about 10 minutes. I think one of the accessories is not spinning freely at these temps.
Going into shop soon. I agree with Birdman the tensiner is to week. I can turn it by hand with little or no effort, seems to be a poor design in the belt area.
[This message has been edited by Don C (edited 01-19-2000).]
i have a 2000 it makes a little belt noise on a cold start up ( 30 or -) but it goes away in a a few minutes it does'nt bother me when it blows i wil get dealer to fix it.
2000 f150 4x4 offroad pkg, 5.4 xlt
Ive noticed this to the past few mornings. Its been really cold in CT this past week, and Ive noticed this noise on start-up. I just turn my radio up
Knock on wood, this is the first strange thing my truck has done, 6000 mi. and counting.....
1999 F150 4x4 XLT BLACK ORP 4.6 5 SPEED 3.55
LUND HOOD SHEILD
K&N
FLOWMASTER SERIES 40
PREMIUM SOUND W/CHANGER
PIONEER 6815's(for now)
SUPERCHIP
AIRBOX MOD
Knock on wood, this is the first strange thing my truck has done, 6000 mi. and counting.....------------------
LUND HOOD SHEILD
K&N
SUPERCHIP
AIRBOX MOD
i heard a similar noise on my 97. i thought for sure it could be the water pump. my truck has 60000 miles. i started to replace the pump when for some reason i spun the fan and heard the squeak. there is a rubber bushing in the fan that needed lube. i sprayed some lithium on it and now no more squeal. maybe this can help some of you.
i think its pretty clear this noise is from the drive belt bieng glazed. given that replacement belts are that much shorter, it would appear that a shorter belt would be the answer to the problem. I would guess cold weather begins the problem, which only gets worse everytime the belt drags. If you guys can get the belt replaced, i would bring in the gatorback belt for them to put in for you instead of the ford belt. I have the problem too, but aint ready to leave it overnight yet so they can hear it. too much trouble at this point.
I'm looking for help on a cold start noise on a 1998 F150/4x4/EC/4.6 V8/AC. As
soon as it comes off of high idle the belt/pully area starts a squeeky/rattle noise. Its
rhythmic with the belt rotation. Depending on the ambient temperature it goes away
with about 20 miles of driving.
The dealer has thrown a new belt/tensioner/crank pully on all to no avail. They have
no solution. After the last repair that involved replacing the 2 pullys the noise was
gone for abou 2 days. Its back.
There are no TSB's or factory fixes. An internet search revealed a discussion of this
problem here at F-150 online with solutions ranging from the above to changing to a
Goodyear or Gates belt to lubricating the rubber bushing on the fan all the way to
turning up your radio so you can't hear it.
I know this is an old thread but I was curious if there are any final solutions that have not been posted.
Any help on this would be appreciated.
Thanx
Greg
mailto:grege@execpc.com
Thanx
Greg
