Oil Change
Old Jan 21, 2000 | 04:48 PM
Road Runner's Avatar
Question Oil Change
I have a 1998 f-150 4.2L Six quarts of oil just isn't enough to meet the minium on my dipstick. is the dipstick wrong or the book that came with my truck.
[This message has been edited by Road Runner (edited 01-21-2000).]
My dealer said the part number stamped on it is for 1997 F-150
How many quarts does an 1987 take?
[This message has been edited by Road Runner (edited 01-22-2000).]
Old Jan 21, 2000 | 06:13 PM
Dewy's Avatar
Post
When are you taking the oil reading? Do you give the oil time to drain back down into the pan? 6Qts is the MAX I would ever run, I keep it at 5.5 and I am in good shape...
Old Jan 21, 2000 | 06:35 PM
Karick11's Avatar
Talking
Six quarts puts mine exactly at the top line, thats wierd about yours. Did the paving contractor have a good jag on when they did your driveway?? LOL......
"99" F-150 4x2,ext, med red / silver, 4.2L, auto, 3.55's, 265x16's premium snd w/cd, 4 wheel antilocks, leer "too heavy" matching cap, Mobil 1.
Old Jan 21, 2000 | 06:48 PM
MOVEOVER's Avatar
Post
6.2 with filter, right?
White 97 XLT SC 4.6, 4X4, 3.55ls, door cracks, tow pkg, long bed, Rhino liner, Owens running boards
Old Jan 21, 2000 | 06:56 PM
BigBunnell's Avatar
Post
Mine takes six on the mark. But some engines may take more to fill.
while we're talking about oil changes with the 4.2 does any body know of a way that you can drain the oil with out it shooting out sideways almost to the passenger side tire, or remove the filter without the oil running all over the axle on 4x4 models. Does anyone have any thoughts on filter relocation kits?
BigBunnell
98 F150 4X4 XLT flareside V6 5sp K&N Flowmaster and some other goodies
Old Jan 22, 2000 | 08:19 AM
msparks's Avatar
Post
BigBunnell,
On the splashing thing, I use a funnel(big one) so that it will catch the oil and make it go in to my drain pan, It seems to work well.
The filter relocation kits are available, the way that it works is that there is an adapter that fits onto your current filter area, then with the hoses that are attached you can mount your filter just about anywhere.If you mount it correctly you should have no leaks either. Also you can mount it verticle, so when you change it You don't spill any. Or you can mount it horizontal as long as it is on the bottom half of a 180 degree arc. Meaning you cant put it upside down or even at an up angle.
Lube-Direct
Old Jan 22, 2000 | 01:11 PM
Katmandu's Avatar
Cool
My 1997 4.2L uses 6 quarts even with a shiney new motorcraft filter...BTW the Motorcraft filter has metal on both ends (Fram has cardboard) and a silicone valve...worth the $.50 extra...FYI
1997 F-150 Reg. Cab/Short Box, 4.2L, Auto 3.31 Rear, Black/Silver
Old Jan 23, 2000 | 09:50 AM
Bowtie's Avatar
Post
6 quarts with filter that is all you need. On my dipstick this comes up to the 3/4 mark. The owners manual says six quarts so that is what I use. Here are some facts for us 4.2L owners.
4.2L 6 quarts of oil = 1.42 quarts per liter or 1 quart for every cylinder.
4.6L 6 quarts of oil= 1.30 quarts per liter or .75 quarts for every cylinder.
5.4L 6 quarts of oil= 1.11 quarts per liter or .75 for every cylinder
6.8L 6 quarts of oil= .88 quarts per liter or .60 quarts per cylinder
So what does this mean? The 4.2L might last longer because of the amount of oil in the engine.
98 F-150 XL 4x4, 4.2L, 5sp, 3.55 LS, tow package, 8 ft box, P255x70 R16
Old Jan 30, 2000 | 01:57 PM
BigBunnell's Avatar
Cool
What about the PSD? 7.3l and 14qts of oil. thats 1.92 qts/liter
and 1.75qts/cyl
kinda makes your gasser feel under lubricated don't it
Btw thanks for the replies, I was venting after a oil change, I do want to do the filter relocation, but I think I'm gonna try to find something else, i'd hate to have to battle ford over warranty claims for it.
BigBunnell
Old Jan 30, 2000 | 02:54 PM
PaulT's Avatar
Post
I've been putting 6.5 quarts per oil change because that's what it takes to hit the top of the fill mark! Maybe I should rethink this!
Paul...
99 F-150 XLT SC Sport, 4.6L, Auto, Captain Chairs, Class III Towing Package, 3.55 LS, Sliding Rear Window, White, 4X2, CD, Soft Factory Tonneau Cover, K&N Filter, WMS Velocity Tube, Line-X Spray on Bed Liner, Gibson Side Swept Cat Back System, F150online Decal...
More to come!
ptarnuzzer@megsinet.net
Old Jan 30, 2000 | 07:02 PM
roadrunner's Avatar
Post
Hey Road Runner, this is roadrunner - welcome to F150 online.
six LITERS of oil brings the level on my D/S reading almost to the max line - I filed a little mark at that point & now can keep accurate track. Maybe Ford did change dipsticks.
I can see how it would be confusing.
Have you asked your dealer abt this.?
98 F150 S/C 4.6 2wd Vermillion/Silver,HD Tow Pkg, Boards, Vents, Lund Bug Chaser, DIY "breezer" Tailgate, 5th whl hitch, Tool box, 16" OEM Mag's,BEEP,BEEP roadrunner floor mats.
Mobil1 /Wix Oil filter/ K&N / air box mod.
In looks & go - Chevy - like a rock.
Old Jan 31, 2000 | 09:48 AM
Post
Yes I have checked with my dealer and found out that the dipstick in a 1997 and 1998 truck are different and the one i have belongs to a 1997 4.2 they have ordered me a new one.
