Coolant Change
Old Oct 8, 2001 | 02:48 PM
97GreenLariat's Avatar
Coolant Change
How do ya'll do a coolant change?
Old Oct 8, 2001 | 06:54 PM
MitchF150's Avatar
Wink Just the way I did it...........
Not saying this is the only way, just what worked for me when I did mine........
When I changed mine, I just opened the drain for the radiator, let it drain. Filled it up with water, let it drain. Filled again, started engine. When top hose got hot (t-stat opened), I let it run for 30 sec and then shut it off. This let the clean water in the rad get replaced with the old from the engine. Drained this. Filled with water, repeated until only clean water came out.(two more times I think). Filled agian, let it run for like 15 minutes more with rad draining and then filling as the resovoir emptied. Oh yeah, turn the heater on full when doing all this.
I then used that flush stuff from Prestone. Let it run for another 15 minutes. Then repeated the above process to remove all the flush stuff.
I also used an old hose end that had the tip cut off and pushed it into the resovoir and down the big hole at the bottom that attaches to the lower rad hose. Kinda makeshift flushing kit. Only did this while engine was running so the cold water wouldn't crack anything....... Actually, I think it only went into the rad, because the water out the drain would increase when I did this. Helped speed that procees along, plus put clean water back in system.
Drained rad again, and filled with two gallons of Prestone. It took it all. Since the spec is really close to four gallons total, this will make a near perfect 50/50 mix. Just started the engine and let it run. Left the cap off the resovoir, so that any air bubbles that may have been in the system just escaped as the water circulated. Kept an eye on it for a couple of days afterward. Never had to add anymore. Checked with that 'tester' gizmo and was just right. Probably took two hours or so for the whole process.
Like I said, this is what worked for me. Other's have said they open the block valves too. I just decided I didn't need to go that far with the flush cycles I performed. Besides, I also heard that the passenger side block valve is impossible to get to......
Old Oct 8, 2001 | 09:38 PM
Thanks Mitch - - I'll try that
