2003 f150 xlt
Unfortunately, the information provided is both contradictory and insufficient. If the engine cranks, there's power going to portions of both fuse boxes. The fuses named are ones that are only HOT IN RUN/START. Further, how can there "Starter solenoid terminal getting no power from the positive battery cable" when the test light clearly shows that there is power?
OP: Try again. Provide more detailed and complete information regarding observations. Look at your odometer, check engine light and the THEFT light when the ignition switch is turned from OFF to RUN.
