Need help
Old Feb 20, 2022 | 09:35 AM
Racked brain's Avatar
Need help
So my 2010 f150 4.6 destroyed my left phaser, do to my own negligence. As of now I got cylinder 7 misfire and both cam timing over retarded. Iv already change both phasers, cam sensors, crank sensor, vvts, oil pump, engine flushes, timing tensioner, plugs, and swaped all cops. Still cylinder 7 and over retarded codes, Any one have this, some advise would be nice
Old Feb 20, 2022 | 09:43 AM
Roadie's Avatar
Did you use Motorcraft parts?
Check the compression in 7. If it's good, swap plug, then swap cop, then injector with another cylinder to see if the misfire moves.
Old Feb 20, 2022 | 09:54 AM
No misfire doesn't swap with plug and cop swap
Old Feb 20, 2022 | 08:03 PM
Got rid of misfire code with Electrical cleaner at connectors. Compression test good all cylinders 150 psi., still have rough idle after warm up, going to check oil pressure again to rule out losing oil pressure at bearings throughout engine. Suggestions from other mechanics say orieleys phaser go bad within the hour, so I'm at a lose until I do oil psi test.
Old Feb 20, 2022 | 09:41 PM
When you do a timing job on a Ford 3 valve, you should use only Motorcraft parts, with the exception of a Melling high volume oil pump. If the O'Reilly phasers are Dorman, those are junk.
Old Feb 20, 2022 | 10:01 PM
Yes I'll be pulling it back apart next weekend
