Timing chain knocking
Timing chain knocking I changed the cam phasers the lifters the guides tensioners it start real nice but after it gets warmed up the chain starts hitting on the passage side you can literally see the chaine smaking back and the chain is on there nice and tight can some one help me and I didn't Chang the oil pump neither
What are you working on? I assume it's a 4.6 or 5.4 3 valve of some unspecified year.
When you do a timing job on those engines, you should use all Motorcraft OEM components - chains, guides, tensioners, phasers - and a Melling high volume oil pump.
This is part 1 of a 4 part video - watch it on YouTube, read the description for parts list and links to the next 3 parts.
