Fuel pump
Old Jan 7, 2020 | 07:07 PM
shope7's Avatar
Fuel pump
Has anyone tried cutting a hole in the bed to access the fuel pump? 05 flareside
Old Jan 8, 2020 | 12:10 AM
Why don't you just lift the bed?
Old Jan 8, 2020 | 11:11 AM
Some folks don't have access to a hoist/rigging or even other people at times.
So in his case, likely the only way is to cut a hole in the bed.
If done correctly, it's actually a nice addition.
It's like when I used to have my staxx. The holes are excellent for cleaning the bed, as the water and dirt doesn't accumulate. I also didn't have any bed rust before I had a 3M lining installed. It would be a nice addition on new trucks to have drain plugs.
My new truck, that is one of the first things I am doing, is hole sawing minimally two 2" holes on each rear corner of the bed.
Old Jan 10, 2020 | 08:38 AM
JCR 56's Avatar
Yes you can. Might want to lay something over the tank to deflect the sparks just to be safe. I would use a 41/2" grinder with a cut off disc, not a torch.
