Fuel level sensor
Old Dec 16, 2019 | 01:15 PM
shope7's Avatar
Fuel level sensor
I have an 05 f150 4.6 with 270k miles. I have been getting the fuel level sensor code for months now. The cel comes on and eventually goes off but then comes back on. The fuel gauge works fine. What’s the deal?
Old Dec 16, 2019 | 02:12 PM
What is the exact numeric code?
Old Dec 16, 2019 | 04:19 PM
shope7's Avatar
It said, “fuel level sensor circuit range/performance “. I don’t remember the numbers.
Old Dec 16, 2019 | 05:10 PM
That's: P0461
It might be your FPDM.
Old Dec 16, 2019 | 06:24 PM
This can happen if you fill the tank with the key on.
Old Dec 17, 2019 | 12:42 AM
shope7's Avatar
And I have done that. So since the fuel gauge is still working, should I not worry about it now?
Old Dec 17, 2019 | 10:34 AM
Don't leave the key on when you fill it up any more, and only worry if the code comes back or the fuel gauge stops working.
https://www.obd-codes.com/p0461
P0461 could have been set because of mechanical (incorrect fuel level rationality; refueling the vehicle with the ignition switch "on" or even engine running can do this. Fuel level changes too rapidly which is not normal) or electrical (FLS sensor circuit) issues. These cannot be overlooked in the troubleshooting stage, especially when dealing with an intermittent problem.
Old Dec 17, 2019 | 11:04 AM
As far as I know, it's illegal, or minimally frowned upon to fill a vehicle up with the key on, engine running.
Old Dec 17, 2019 | 12:07 PM
projectSHO89's Avatar
While "hot fueling" is a very bad idea on any vehicle, it should not cause any sort of error on a Ford. It should only result in a fuel gauge indication that takes an extended time to register properly.
Have you run the instrument cluster self-test to see if there are any stored error codes in the cluster?
Old Dec 17, 2019 | 02:04 PM
Old Dec 17, 2019 | 08:39 PM
Yeah, I read that. It's wrong (the part in bold, that is).
Quoting a non-Ford source isn't a very good idea. Those are generally generic descriptions that may or may not apply to what Ford did in implementing that DTC. In this case, it's "not". Recommend checking ONLY Ford's documentation starting with the relevant OBDII theory manual and cross-checking with the PCED.
