Won’t start
Old Mar 26, 2019 | 09:20 PM
Smitty06KR's Avatar
Won’t start
So I was driving home and all of a sudden my truck cut off. I managed to pull to the side of the road and tried starting the truck back up. It started up but once I put it in drive and pressed the gas it cut off. Tried the same thing again and got the same results. After sitting for about 10mins I just turned the key over to notice if any lights were on. I noticed that the old pressure was reading low. I walked to dollar general and purchased some oil. I put 3quarts in and still reads low oil pressure and won’t start. Any ideas. I don’t know if it’s fuel related or oil related.
Old Mar 26, 2019 | 09:30 PM
projectSHO89's Avatar
If the engine wasn't running, of course the oil pressure would read "low", like zero.
Old Mar 26, 2019 | 10:49 PM
Did you check the oil on the dipstick before adding any? Have you checked it since to see how overfull it is now?
Can we *assume* due to your username this is a 2006 King Ranch with a 5.4?
The dying out could be just about anything, but a likely cause is a corroded FPDM. It's on the frame above the spare tire, it controls the fuel pump.
Old Mar 26, 2019 | 11:29 PM
Smitty06KR's Avatar
yes it’s a 06 king ranch. I replaced the fpdm today and it still won’t start. I also drained some of the oil from the oil pan as well.
Old Mar 27, 2019 | 08:20 PM
Smitty06KR's Avatar
VCT Solenoid
I also replaced both VCT solenoids and it still won’t start. Oil pressure raises halfway then drops back down as if it’s empty
Old Mar 27, 2019 | 09:56 PM
It's time to check for spark and fuel. You need a spark tester and noid lights to see if the injectors are firing.
Spark tester:
Amazon Amazon
Noid lights:
Amazon Amazon
