Code P1131
Old Dec 22, 1999 | 09:38 PM
BigRed2's Avatar
Question Code P1131
Can any body give me the specifics on this code. I am trying to determine if the dealer is jacking me arround.
Thanks.
99' F-150 XLT SC 4X4 ORP LS 4.6L K&N Air Filter Air Box Mod (3" intake from fender & silencer removed), Superchip, A.R.E. Cover, Duraliner bed liner, Rapidflow 3" single CatBack exhaust.
Old Dec 22, 1999 | 09:42 PM
BigRed2's Avatar
Post
I should have said code P0131.
sorry
Old Jan 15, 2000 | 08:14 AM
JMTruck's Avatar
Post
From the Hayne's Manual PO131 probable cause is an upstream heated O2 sensor circuit low voltage (bank 1 ).
98 4x4 Lariat SC 5.4L ORP, Tow Package, 3.55 LS in oxford white two tone. Only modifications, K&N Filtercharger and Stepshield door still protectors. Many more to come.
Old Jan 15, 2000 | 09:24 AM
Dustoff's Avatar
Post
JMtruck is correct....The 1997-2000 Chilton's manual lists code P0131:
P0131 - O2 Sensor Circuit Low Voltage (Bank no. 1 Sensor no. 1)
2000 F-150 XLT, 4x2, 5.4L Supercab, Styleside, Black with silver two-tone, 3.55, class III towing package with heavy duty cooling package, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, Pendaliner bedliner, K&N air filter, rubberized undercoating, cabin filtration system, Bugflector II, 5W-30 Mobil 1, engine build 10/4/99
Old Jan 17, 2000 | 01:20 AM
birdman's Avatar
Post
I think this is the lean code. Codes are not stored unless there is a continuous problem. Problems: Faulty injector, faulty O2 sensor,(seen lots of these), MAF elements are dirty and causing a borderline lean, fuel pressure low.
Stay with it until it is resolved, you don't want to burn a piston up.
Birdman
