Thermostat Temperature
I was told the thermostat in the Lightning trucks is 180 degrees stock, is this correct?. Will the thermostat from a Lightning fit a 4.6?.
Thanks for the help.
Larry.
Larry.
The thermostat will interchange, however I do not recommend changing to a lower temperature thermostat unless your SuperChip is programmed for it. The computer expects a certain temp range from the temp sensor and will run rich and generally poorer if the temp is brought below the expected range - i.e. changing thermostats.
