2000 in a 1999 its just fine
Old Jan 15, 2000 | 03:03 PM
Offroader1999's Avatar
Talking 2000 in a 1999 its just fine
Just got my truck back after a week. I had piston slap engine replaced. The tech did a very good job. I took it back to my shop to check it out. The only thing I found that he forgot to do was tighten up rear trans mount. I went back and told him this, all he said was your right I did forget that. I gave him a good tip. Runs great and no noise. At this point Ford is Ok with me.
Old Jan 15, 2000 | 03:09 PM
fast46triton's Avatar
Post
Does it seem to run any better/different?
Ford has had my trust for a while now.
Old Jan 15, 2000 | 03:19 PM
Post
Runs as good as my 99 engine, I have not got into it yet it only has 103 miles on it. After the first 1,000 miles and an oil change I will let you know. It has different injectors and intake.
Old Jan 15, 2000 | 04:27 PM
Post
What engine did you have? If it was a 4.6l, was it a windsor or romeo? I think my Romeo 4.6l might have Piston Slap.
Fast46Triton ®
1999 Ford F150 XLT Supercab, Shortbed, 4x2, 4 wheel disc brakes/4 wheel Anti-Lock Brakes, Cloth Seats, Amazon green, 16" All season tires, Soft Tonneau Cover, CD Player, 4.6 liter Triton V8 with possible piston slap!, 3:55 ls, towing package, 4 speed auto, K&N Airfilter
Old Jan 15, 2000 | 05:03 PM
Dennis G. Morgan's Avatar
Post
Had my '99 5.4L replaced with a 2000(fresh in the crate)engine from the Windsor plant three months ago. Dealer did a great job. Mine had Cold Start Knock/Piston Slap with the oil leak at the rear of the right head. On mine they removed the 2000 intake manifold(including the injectors)and the exhaust manifolds and installed the intake/exhaust manifold(s) from the '99. From previous posts, some had the change done this way and others with the complete 2000 engine. It looks to me that the early changeouts on the '99 5.4L had transplanted manifolds and now the entire 2000 engine is being installed, with a ground strap relocated from the old aluminum intake and the computer reprogrammed.
Any comments?
"99 F-150 SC,4X4,5.4L, Lariat/Capt.Chairs,K&N, SuperChip,Gibson Catback,
OxfordWhite/Black Lower
[This message has been edited by Dennis G. Morgan (edited 01-15-2000).]
Old Jan 15, 2000 | 11:10 PM
Post
They do have to take the manifold off to install the engine, but they should have reistalled it the 2,000 intake and injectors. Was your's replaced with an 2,000 engine
99 F150 xlt s/c orp auto, 2,000 5.4 replacement soft tonneau, rubber maid bed mat,mud from the dirt bike(YZ250)
Old Jan 15, 2000 | 11:13 PM
Post
Sorry it's an 5.4, as for coments I think that this engine will rock after the brake in
Old Jan 16, 2000 | 08:42 AM
crow150's Avatar
Post
Offroader, believe me, it will ROCK! I just got oil changed at 1050 miles and lit em' up! With cold weather here, I am getting 12-14 MPG. Much better than 10 MPG I got on the first tank of gas after replacement.
1999 ORP SC Medium Toreador red 5.4L (2000) 17" Centerline Prowler wheels Deflectashield Magnum hood shield K&N air filter, all options except leather dont need anything else-its bad to the bone!
Old Jan 16, 2000 | 10:36 AM
Post
You gave it hell after the first oil change, I will stomp it also after my first. It kinda thows you off looking at the speedometer and seeing 6,000 miles but engine only has less then 200, kinda hard to keep your foot out of it.
