2001 F250 Wont Crank
Old Jan 14, 2018 | 08:12 PM
JCR 56's Avatar
Hate to say it, but it's probably the starter.
Old Jan 14, 2018 | 09:22 PM
Fence Guy's Avatar
My gut says starter, otherwise I don't believe id get a click at the starter, a bad relay would do nothing, although a bad contact could give a low voltage at the starter which I should check also tomorrow.
Old Jan 14, 2018 | 09:41 PM
The ground strap on the starter rots out on these trucks.
Old Jan 14, 2018 | 09:56 PM
Fence Guy's Avatar
Is the ground strap the small lug on the starter? I hit that with the clamp on the trigger starter at the same time as the other lug and it lit up,lol.
Old Jan 15, 2018 | 08:47 PM
Fence Guy's Avatar
Update: It was the starter relay contacts that were bad, bought a new one and its all done. I'm glad it wasn't the starter, wasn't looking forward to doing that, its supposed to snow again tomorrow. Thank you everyone for your input.
Old Jan 15, 2018 | 09:24 PM
No problem. Glad it was an easy fix.
Old Jan 15, 2018 | 09:25 PM
You talking about the relay on the firewall? That's a common failure.
Old Jan 16, 2018 | 08:20 AM
JCR 56's Avatar
Glad it was an easy fix. Winter is the absolute worst time for a vehicle to screw up if you don't have a garage. They are giving snow and single digits here.
Old Jan 16, 2018 | 09:02 AM
Yup, we got the same here. It's always the "worst" time when a vehicle gives no start issues.
I had the fuel pump go out on my Compass, and my mother was using it to go food shopping. It was 90F, and a trunk load of groceries (~$200). Luckily I was at work with a truck, so I came by and loaded my truck up with the groceries while she dealt with the tow truck to get it to my house. Any other time it would've been fine... but no, we had expensive cargo!
Old Jan 16, 2018 | 09:49 AM
Roadie's Avatar
Thanks for letting us know what the fix was.
Old Jan 16, 2018 | 12:03 PM
Yep, I had fun changing a headlight bulb in the parking lot at Autozone yesterday. It was about 15 degrees and snowing lightly.
