bad pcm
Old Jan 2, 2018 | 11:48 AM
nickn's Avatar
bad pcm
2007 f150 5.4 not getting signal to coils also starter does not disengage has new starter coils plugs
Old Jan 2, 2018 | 02:03 PM
What is your question? This isn't Twitter, there's no character limit.
Old Jan 2, 2018 | 04:41 PM
nickn's Avatar
When i changed spark plugs and cleaned throttle also disconnected battery put every thing back together truck was missing bad . Changed all coils still did same thing . I took spark plugs back out cleaned reinstalled same thing and now starter staying engaged .I changed starter still staying engaged .I changed ignition switch and crank sensor checked all fuses and relays still will not run starter stays engaged and not getting signal to coils from pcm . Battery has 12.8 volts 14 when charged .Also visual checked all wires to pcm 2007 f150 5.4 124,000 miles my question is the pcm bad . please need help
Old Jan 2, 2018 | 05:37 PM
Have you tried hooking the truck up to a OBD scanner? If so, any codes? Any communication problems?
Old Jan 2, 2018 | 06:32 PM
nickn's Avatar
No codes
Old Jan 7, 2018 | 07:15 PM
nu-supercrew's Avatar
How was it running before you changed the plugs and cleaned the throttle body?
Old Jan 8, 2018 | 11:22 AM
nickn's Avatar
Running ok but needed spark plug change with 120,000 on it . I went over my work checked everything.
